This is made with dashboard buttons and text input nodes:
It respects the chosen theme.
How can I get this styling for elements in the Template UI node?
For example, the following code produces this:
<md-button style="width: 100px; height:40px;" ng-click="send({action: 'new_scene', zone: msg.zoneid})">Save</md-button>
<input type="text" ng-model="scenename" name="string" ng-change="send({action: 'update_scenename', name: scenename})" />
Display inline: I can't make it work with CSS and additional HTML such as wrapping the button and input in
<span> or <div>
- I have tried to mimic the HTML generated by Node-RED by wrapping in elements like
<md-card> and <md-input-container> but I get strange results
Any ideas?
Hi @hazymat, Here's an example ui-template that I figured out to fix the button issue. As an example I'm using a button to start fullscreen on the browser.
<style>
#go-fullscreen-btn {
height: 100%;
border-style: unset;
.btn-parent {
padding: 0 !important;
</style>
<md-button id="go-fullscreen-btn" ng-click="send({payload:action('go fullscreen')})" type="button">Go Fullscreen
</md-button>
<script>
fsElem = document.documentElement;
theParentElem = document.getElementById("go-fullscreen-btn").parentNode
theParentElem.classList.add('btn-parent')
this.scope.action = function(params) {
console.log("params received is: ",params)
if (fsElem.requestFullscreen) {
fsElem.requestFullscreen();
} else if (elem.mozRequestFullScreen) { /* Firefox */
fsElem.mozRequestFullScreen();
} else if (elem.webkitRequestFullscreen) { /* Chrome, Safari and Opera */
fsElem.webkitRequestFullscreen();
} else if (elem.msRequestFullscreen) { /* IE/Edge */
fsElem.msRequestFullscreen();
// In fullscreen. Now hide the button.
document.getElementById("go-fullscreen-btn").classList.add('ng-hide');
return {payload:"Fullscreen is active."}
</script>
Thanks for your post. In the end I got it working and I think it was the introduction of !important that resolved my issue.
Side note: I may use that "fullscreen" idea, for a wall controller I have installed. I really like it!
I'll post my CSS here as well, although I suspect it will be easier for most people to figure this out themselves, than to go through and weed-out what they need from all the CSS here:
<style>
input {
width:150px;
margin:0 22px 0 0;
display:inline;
border-color: #eeeeee;
color: #eeeeee;
border-bottom-width: 1px;
font-family: inherit;
background: none;
padding: 2px 2px 1px;
border-width: 0 0 1px;
line-height: 26px;
height: 40px;
-ms-flex-preferred-size: 26px;
border-radius: 0;
border-style: solid;
box-sizing: border-box;
float: left;
.scenemanageselect {
width:40%;
margin: 0 20px 0 0;
md-select span {
color:#eee;
md-select .md-select-value.md-select-placeholder {
border-bottom-color: #eee;
.md-select-value .md-select-icon:after {
color:#eee;
md-select.md-default-theme .md-select-value, md-select .md-select-value {
md-select.md-default-theme:not([disabled]):focus .md-select-value, md-select:not([disabled]):focus .md-select-value {
border-bottom-color: #0eb8c0;
.md-button {
height:38px;
.md-container {
.deletebutton {
display:inline !important;padding:10px;height:38px !important;
width:120px;
margin:0 20px 0 0 !important;
background-color:rgb(153, 71, 0, 0.65) !important;
.updatebutton {
width:120px;
background-color:rgb(153, 144, 0) !important;
.control-row {
display:inline-flex; margin: 10px 0 10px 0
</style>
<!--New Scene-->
<div class="control-row">
<input type="text" placeholder="Scene ID" ng-model="msg.sceneid" name="string" ng-change="send({action: 'update_sceneid', sceneid: msg.sceneid})" />
<input type="text" placeholder="Scene Name" ng-model="msg.scenefriendly" name="string" ng-change="send({action: 'update_scenefriendly', scenefriendly: msg.scenefriendly})" />
<md-button style="width: 100px; height:40px; display:inline" ng-click="send({action: 'new_scene', zone: msg.zoneid})">Save</md-button>
</div>
<div ng-if="msg.notify === true">{{msg.notification}}</div>
<!--Delete / Update Scene-->
<md-select ng-model="msg.someModel" placeholder="Select a scene" class="scenemanageselect"><md-option ng-value="key" ng-repeat="(key, value) in msg.scenes" ng-click="send({action: 'select_to_delete', name: key})">{{value.friendly_name}} - (ID = {{key}})</md-option></md-select>
<md-button ng-click="send({action: 'updatescene', zone: msg.zoneid})" class="updatebutton" >Update</md-button>
<md-button ng-click="send({action: 'deletescene', zone: msg.zoneid})" class="deletebutton" >Delete</md-button>
</div>
