How to trigger a flow if a newer version is released?
Hello Guys,
Im looking to set up some proactive notifications to alert me when there is a new version of Node-Red available for installation. Ive been hunting around trying to find this information but keep coming up blank.
Any ideas how I can trigger a flow if the installed version of my Node-Red package is older that the current stable version?
To take this one step further also, would be great if I could also set up a trigger if an update for a pallette becomes available.
hello .. you can use an exec node and run an npm outdated -g node-red -json command
that will produce a msg if its outdated showing the current and latest version that you can later compare.
Test Flow :
[{"id":"04c5f9106d71fd16","type":"inject","z":"54efb553244c241f","name":"npm","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":290,"y":2220,"wires":[["fcab4315b32afd57"]]},{"id":"fcab4315b32afd57","type":"exec","z":"54efb553244c241f","command":"npm outdated -g npm -json","addpay":"","append":"","useSpawn":"false","timer":"","winHide":true,"oldrc":false,"name":"","x":540,"y":2220,"wires":[["a3b2d655e720507e"],[],[]]},{"id":"bcc5858fa3756b16","type":"inject","z":"54efb553244c241f","name":"node-red","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":2360,"wires":[["ea814dc339e97c59"]]},{"id":"ea814dc339e97c59","type":"exec","z":"54efb553244c241f","command":"npm outdated -g node-red -json","addpay":"","append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"","x":530,"y":2360,"wires":[["a3b2d655e720507e"],[],[]]},{"id":"fdd4d5d2092cf6ed","type":"debug","z":"54efb553244c241f","name":"debug 30","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":940,"y":2280,"wires":[]},{"id":"a3b2d655e720507e","type":"json","z":"54efb553244c241f","name":"","property":"payload","action":"","pretty":false,"x":790,"y":2280,"wires":[["fdd4d5d2092cf6ed"]]}]
In the test flow i run a command for npm that i know is outdated and node-red that is the latest.
i notice that if the package is updated though you dont get any result?!
so you need to handle those cases after the json node.
Thank you so much, Worked as you explained.
