How to use custom font in ui-text?
I need to define a font in ui-template first. But I don't know how to reference the new font to a used ui-text.
<style>
    @font-face {
        font-family:segment;
        src:url "(http://127.0.0.1:1890/switch/assets/Seven_Segment.ttf)";
</style>
We have an example for overriding font in our docs. You are better off declaring this in a UI Template that is of type "CSS (UI Scoped). Then no need for the <style> tags.
You should then be able to reference "Segment" in a second CSS declaration. There is an example in the docs
I make this in a ui-template but ui-text font isn't change!
You've got a typo in the font-face declaration. The " should be around the URL, but not the ( )
.nrdb-ui-text sets the font-family to Helvetica. Can't see any good reason doin so but if user wants to change whole page, the ui_text is the thing to adjust separately.
Why ui-text's label font not change but group label font have changed
inspect the dashboard yourself using the browsers devtools and you will find the class for the class for the value part is .nrdb-ui-text-value
To further limit the CSS from affecting ALL text nodes, you should add a class to ONLY the ui-text widget you want to have this font (e.g. seven-seg) then address it like this:
.seven-seg .nrdb-ui-text-value {
    font-family: "segment";
OK !
