How to use node s7 to show pie chart
hello , I have data from S7 and I want to show on pie chart in dashboard but it didn't showed.
I don't know how to use pie chart to show my data from my S7.
please
There is a line in the 'Help' tab:
See this information for how to pre-format data to be passed in as a complete chart.
If you follow that link it will show you how to format msg.payload for a Pie chart and there are some examples you can lok at/test with.
I'm sorry , I don't know how to use that code. Where do I enter that code? Can I edit chart node or Add function and enter code.
Did you try importing the example so you could see how it works?
I can't do that.
Use CTRL+I to import a flow (don't put it in a function node - it's not JavaScript)
Thank you so much!
