How can i use serial port control node to change the port and other parameters on the fly. Kindly help someone.
Have you read the built in help on the side bar in your node-red editor?
Stops, starts the serial communication and changes the serial port configuration.
This node provides the serial port control capability to
- stop the communication and releasing the serial port so, for example the Arduino can upload the new binary without shutting down the nodered.
- start the communication after stopped with this `Serial Control` node for above reason or the like.
- change the serial port and the configuration on the run time programatically.
- query the serial port configuration if empty or no valid configuration parameters are passed.
Inputs
In order to control the communication, just send these JSON messages to the control node.
{ "serialport": "/dev/tty.usbmodem1234561", "serialbaud": 115200, "databits": 8, "parity": "none", "stopbits": 1 "enable": true }changes the serial port and the configuration on the fly.The following optional parameters will change the configuration only if they are present.
Any combination of them can be passed to change/control the serial communication
- serialport
- serialbaud
- databits
- parity
- stopbits
- dtr
- rts
- cts
- dsr
- bin
- out
- enable
When the
enableproperty is not present, it will default totrue
{"enable":true}or{"enable":false}will start or stop the communication.If
enableis passed along with other parameters, the configuration will be changed and either be started or just be ready to be started(ie. stopped ) depending on its value.Outputs
msg.payloadis the response. It contains the serial port configuration
There is also info in the NPM README: node-red-node-serialport - npm
And this readme in the source: node-red-nodes/io/serialport/README.md at master · yhur/node-red-nodes · GitHub
This
resource even has a demo flow you can import!
