Hi!
I have a question about the Serial-node.
I would like to make a button that changes between two different settings for a serial port. It will be using the same serial port, but with different settings, parity, stop bits, etc.
Is it possible for me to either change what Serial port config the node is set to, or edit one of the Serial port configs properties by for example clicking a button in the UI? Thanks
