Orfait
26 October 2018 09:34
1
Hi here,
I am using intensively the serialport node and need to have the ability to change the baudrate on the fly.
This is possible and I was able to modify the node to do so.
In fact, I would like to share the modification but I don't know the process. It is the first time I use github and I am not a professionnal developper.
Any help would be greatly appreciated.
Modification is here :
module.exports = function(RED) {
"use strict";
var settings = RED.settings;
var events = require("events");
var serialp = require("serialport");
var bufMaxSize = 32768; // Max serial buffer size, for inputs...
// TODO: 'serialPool' should be encapsulated in SerialPortNode
// Configuration Node
function SerialPortNode(n) {
RED.nodes.createNode(this,n);
this.serialport = n.serialport;
this.newline = n.newline; /* overloaded: split character, timeout, or character count */
this.addchar = n.addchar || "false";
this.serialbaud = parseInt(n.serialbaud) || 57600;
this.databits = parseInt(n.databits) || 8;
this.parity = n.parity || "none";
this.stopbits = parseInt(n.stopbits) || 1;
This file has been truncated. show original
Sorry, I'm also new to node-red, so I can't help with that, but I was looking for change baudrate dynamically, so I'll have a look to your code.
How do you modify baudrate from function node?
In order to publish your node I think you should follow packaging instructions at https://nodered.org/docs/creating-nodes/packaging
from the look of it you send in a msg with a property .baudrate and it changes it . This means you can only do this by sending a message to an out node and it will change both the in and the out.
Orfait
11 December 2018 15:45
4
You are right.
In addition, if payload is absent, nothing is sent out.
Can I change the com port same way? I tried with port and serialport property, but it did not work.
linho
6 June 2019 12:22
6
Hi, copy this code in ******* REQUEST ********* after node.on(...
if (msg.hasOwnProperty("baudrate")) {
var baud = parseInt(msg.baudrate);
if (baud == NaN) {
var errmsg = err.toString().replace("Serialport","Serialport "+node.port.serial.path);
node.error(errmsg,"Cannot parse baudrate property");
} else {
node.port.update({baudRate: baud},function(err,res) {
if (err) {
node.error(errmsg,msg);
verify if there is the function serial.update after write function:
write: function(m,cb) { this.serial.write(m,cb); },
update: function(m,cb) { this.serial.update(m,cb); },
now you can use request node and send msg.baudrate
Hi, did you find a way to change the COM port ? Thanks
As I'm using the baudrate change on my projects and I don't want to stay with 'specific" nodes, I will create a pull request.
It is the first time for me making a pull request, hope it will be accepted.
EDIT:
node-red:master ← Orfait:master
opened 09:27AM - 26 Aug 20 UTC
