How to using http request for this case
I have a Data folder containing zip files:
http-request-break-5
Files data: C:\Temp\Data
and 2 processing flows called Flow1 and Flow2:
■Flow1 will take care of moving all the zip files to the Move, Backup folder
[{"id":"8ede64fb.c4f9a8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b99f1fd5.ac5db","type":"http in","z":"8ede64fb.c4f9a8","name":"","url":"/GetData1","method":"get","upload":false,"swaggerDoc":"","x":200,"y":140,"wires":[["8d95e31a.ac64"]]},{"id":"d049b738.0e79d8","type":"http response","z":"8ede64fb.c4f9a8","name":"http response","statusCode":"","headers":{},"x":720,"y":440,"wires":[]},{"id":"6a09ba08.5442b4","type":"switch","z":"8ede64fb.c4f9a8","name":"i<msg.files.length","property":"i","propertyType":"msg","rules":[{"t":"lt","v":"files.length","vt":"msg"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":380,"wires":[["b40c4912.87afd8"],["11709bf3.dbf504"]]},{"id":"bdd6220f.6f0de","type":"debug","z":"8ede64fb.c4f9a8","name":"msg flow 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":710,"y":480,"wires":[]},{"id":"f2551b2.e61f9e8","type":"switch","z":"8ede64fb.c4f9a8","name":"if i = 5","property":"i","propertyType":"msg","rules":[{"t":"eq","v":"5","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":970,"y":380,"wires":[["cd83dc80.3c09d"],["f0925530.f19478"]]},{"id":"651aa1b0.6dfc3","type":"change","z":"8ede64fb.c4f9a8","name":"i=0","rules":[{"t":"set","p":"i","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":140,"wires":[["6a09ba08.5442b4"]]},{"id":"6593be1f.f3624","type":"change","z":"8ede64fb.c4f9a8","name":"i++","rules":[{"t":"set","p":"i","pt":"msg","to":"$.i + 1\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":140,"wires":[["6a09ba08.5442b4"]]},{"id":"8d95e31a.ac64","type":"fs-ops-dir","z":"8ede64fb.c4f9a8","name":"","path":"C:\\Temp\\Data","pathType":"str","filter":"*","filterType":"str","dir":"files","dirType":"msg","x":360,"y":140,"wires":[["651aa1b0.6dfc3"]]},{"id":"11709bf3.dbf504","type":"http request","z":"8ede64fb.c4f9a8","name":"","method":"GET","ret":"txt","paytoqs":true,"url":"http://localhost:1880/ProcessData","tls":"","proxy":"","authType":"","x":530,"y":440,"wires":[["d049b738.0e79d8","bdd6220f.6f0de"]]},{"id":"a560ae9f.b911d","type":"delay","z":"8ede64fb.c4f9a8","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1100,"y":440,"wires":[["cd83dc80.3c09d"]]},{"id":"cd83dc80.3c09d","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Move","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1260,"y":440,"wires":[["6593be1f.f3624"]]},{"id":"f0925530.f19478","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Move","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1100,"y":320,"wires":[["6593be1f.f3624"]]},{"id":"b40c4912.87afd8","type":"change","z":"8ede64fb.c4f9a8","name":"","rules":[{"t":"set","p":"fileMoved","pt":"msg","to":"$.files[$$.i]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":320,"wires":[["549d105a.50198"]]},{"id":"549d105a.50198","type":"fs-ops-type","z":"8ede64fb.c4f9a8","name":"","path":"C:\\Temp\\Data","pathType":"str","filename":"fileMoved","filenameType":"msg","filetype":"type","filetypeType":"msg","x":720,"y":320,"wires":[["e32832a9.87d4d"]]},{"id":"e32832a9.87d4d","type":"switch","z":"8ede64fb.c4f9a8","name":"","property":"type","propertyType":"msg","rules":[{"t":"eq","v":"F","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":850,"y":320,"wires":[["f2551b2.e61f9e8"],["6593be1f.f3624"]]},{"id":"cb786826.935e48","type":"http in","z":"8ede64fb.c4f9a8","name":"","url":"/GetData","method":"get","upload":false,"swaggerDoc":"","x":190,"y":760,"wires":[["81bd6713.7351e8"]]},{"id":"3e9bd2a0.f949be","type":"http response","z":"8ede64fb.c4f9a8","name":"http response","statusCode":"","headers":{},"x":540,"y":1040,"wires":[]},{"id":"2d56bdb2.3da4d2","type":"switch","z":"8ede64fb.c4f9a8","name":"i<msg.files.length","property":"i","propertyType":"msg","rules":[{"t":"lt","v":"files.length","vt":"msg"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":1000,"wires":[["590e3063.b20c5"],["3e9bd2a0.f949be"]]},{"id":"c940907.375037","type":"switch","z":"8ede64fb.c4f9a8","name":"","property":"i","propertyType":"msg","rules":[{"t":"lt","v":"5","vt":"num"},{"t":"eq","v":"5","vt":"num"},{"t":"eq","v":"6","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":830,"y":1140,"wires":[["9e82c32f.cdd"],["dbe492a1.ec36c"],["ff3da480.478fd8"],["1c1068d9.9a9827"]]},{"id":"de029ce1.0d84d","type":"change","z":"8ede64fb.c4f9a8","name":"i=0","rules":[{"t":"set","p":"i","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":760,"wires":[["2d56bdb2.3da4d2"]]},{"id":"d6c57808.d043a8","type":"change","z":"8ede64fb.c4f9a8","name":"i++","rules":[{"t":"set","p":"i","pt":"msg","to":"$.i + 1\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":1130,"y":760,"wires":[["2d56bdb2.3da4d2"]]},{"id":"81bd6713.7351e8","type":"fs-ops-dir","z":"8ede64fb.c4f9a8","name":"","path":"C:\\Temp\\Data","pathType":"str","filter":"*","filterType":"str","dir":"files","dirType":"msg","x":360,"y":760,"wires":[["de029ce1.0d84d"]]},{"id":"ff3da480.478fd8","type":"delay","z":"8ede64fb.c4f9a8","name":"","pauseType":"delay","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1000,"y":1180,"wires":[["f6094a6f.38e048"]]},{"id":"f6094a6f.38e048","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Backup","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1300,"y":1180,"wires":[["d6c57808.d043a8"]]},{"id":"9e82c32f.cdd","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Move","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1000,"y":1060,"wires":[["d6c57808.d043a8"]]},{"id":"590e3063.b20c5","type":"change","z":"8ede64fb.c4f9a8","name":"","rules":[{"t":"set","p":"fileMoved","pt":"msg","to":"$.files[$$.i]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":550,"y":960,"wires":[["117955ae.da110a"]]},{"id":"117955ae.da110a","type":"fs-ops-type","z":"8ede64fb.c4f9a8","name":"","path":"C:\\Temp\\Data","pathType":"str","filename":"fileMoved","filenameType":"msg","filetype":"type","filetypeType":"msg","x":720,"y":960,"wires":[["f1b91f73.ab03e"]]},{"id":"f1b91f73.ab03e","type":"switch","z":"8ede64fb.c4f9a8","name":"","property":"type","propertyType":"msg","rules":[{"t":"eq","v":"F","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":850,"y":960,"wires":[["c940907.375037"],["d6c57808.d043a8"]]},{"id":"dbe492a1.ec36c","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Move","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1000,"y":1120,"wires":[["31b515cd.4d1dfa"]]},{"id":"31b515cd.4d1dfa","type":"http request","z":"8ede64fb.c4f9a8","name":"","method":"GET","ret":"txt","paytoqs":true,"url":"http://localhost:1880/ProcessData","tls":"","proxy":"","authType":"","x":1190,"y":1120,"wires":[["d6c57808.d043a8"]]},{"id":"1c1068d9.9a9827","type":"fs-ops-move","z":"8ede64fb.c4f9a8","name":"","sourcePath":"C:\\Temp\\Data","sourcePathType":"str","sourceFilename":"fileMoved","sourceFilenameType":"msg","destPath":"C:\\Temp\\Data\\Backup","destPathType":"str","destFilename":"fileMoved","destFilenameType":"msg","link":false,"x":1000,"y":1240,"wires":[["d6c57808.d043a8"]]}]
■Flow2 will output the ListData.txt file containing the names of the zip files in the Move folder
[{"id":"f9f46c0f.0b6ee","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"a11424c6.3c4888","type":"http in","z":"f9f46c0f.0b6ee","name":"","url":"/ProcessData","method":"get","upload":false,"swaggerDoc":"","x":210,"y":140,"wires":[["7e99fcd4.5d19e4"]]},{"id":"f239ecd2.53cbb","type":"http response","z":"f9f46c0f.0b6ee","name":"http response","statusCode":"","headers":{},"x":1120,"y":220,"wires":[]},{"id":"63c9fea6.a693c","type":"debug","z":"f9f46c0f.0b6ee","name":"msg flow 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":850,"y":280,"wires":[]},{"id":"c228109f.8df0f","type":"split","z":"f9f46c0f.0b6ee","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":690,"y":220,"wires":[["28e7f22a.d012ae","63c9fea6.a693c"]]},{"id":"28e7f22a.d012ae","type":"file","z":"f9f46c0f.0b6ee","name":"","filename":"C:\\Temp\\Data\\ListData.txt","appendNewline":true,"createDir":true,"overwriteFile":"false","encoding":"utf8","x":890,"y":220,"wires":[["f239ecd2.53cbb"]]},{"id":"7e99fcd4.5d19e4","type":"fs-ops-dir","z":"f9f46c0f.0b6ee","name":"","path":"C:\\Temp\\Data\\Move","pathType":"str","filter":"*","filterType":"str","dir":"files","dirType":"msg","x":380,"y":140,"wires":[["88adace.207aa5"]]},{"id":"88adace.207aa5","type":"change","z":"f9f46c0f.0b6ee","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"files","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":540,"y":140,"wires":[["ac429f3d.5f6e6"]]},{"id":"ac429f3d.5f6e6","type":"delay","z":"f9f46c0f.0b6ee","name":"","pauseType":"delay","timeout":"300","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":710,"y":140,"wires":[["c228109f.8df0f"]]}]
I would like:
① Flow1 after moving the first 5 zip files to the Move folder will delay about 5 seconds,
② then it will call Flow2 by http request node to output the ListData.txt file containing the names of these 5 zip files
③ and Flow1 continues to move the remaining zip files (Data_0006.zip, Data_0007.zip) to the Backup folder.
⇒ I can do this, but steps ①, ②, ③ need to be performed sequentially ①➡②➡③.
Is there a way while ② is in progress will perform ③?
(Assuming ②'s processing takes a long time, I don't want to finish ② and then do ③)
Is what I want to do is not possible?
Please tell me.
Thanks!
What exact problem are you having? You should be able to have two wires connected to the output of the delay node, one that goes to trigger Flow2 and one that triggers Flow3.
