This is just "a way" to make it more secure, and it truly isn't "The Way".
But in answer to your question, this modification will also protect the dashboard, as it uses the Admin API.
See below (Error 401) - suggesting the dashboard is using the Admin Express Endpoint
Instead of just "including" the list of addrs from a JSON file, you can make a proper Javascript module, i.e. this simple whitelist.js file:
// Allowed ip addresses
const whitelist = [
"127.0.0.1", /* Localhost */
"192.168.1.0/24" /* Private Network */
module.exports = whitelist
Then you can use require in your settings.js like you did before...
> const ipAddrs = require("./whitelist")
[ '127.0.0.1', '192.168.1.0/24' ]
Indeed!
How the whitelist (blocklist in reverse) is fed the IP's - is entirely variable
To use a whitelist... do you need to block all other IP's that are not in the whitelist?
Nope.
The check is -> is this IP in the allowed list, if not... Do One!
The Node JS blocklist should be used as follows
if(BlockList.check(<ip>)){
// Do One!!
} else {
// Allow
I'm just reversing it
// Allow
} else {
// Do One (401)
its a shame they call it a block list for this use case.
In theory you could switch it - but will likely be less effective
Hi all,
I like this discussion. But one thing that stands out to me is, that you only talk about IPV4.
Don’t forget the ever growing other part of the internet: IPV6
It does support IPv6
Just have to modify the code to state it’s an IPV6 address
If you refer to the NodeJS blocklist class, the code will need modifying so it knows when to state it’s an IPv6s address.
I have updated the security FAQ with references to Node.js security best practices, the blocklist functions and this thread.
Update 2025-02-19
The best advice for most people doing home automation is still:
Don't expose Node-RED to the outside world!
Where you really have to have some outside access, keep it as hands-off and restricted as possible. For example, using a Telegram bot.
Also keep it as minimal as possible, e.g. Don't expose the Editor - EVER!
If you want to provide remote control of your heating or the precious plants in your greenhouse, provide explicit controls with strong limits. Don't expose ever…
