Does the html node require more than just a string in msg.payload or does the template node encode the content ? (ie. it looks like html but actually uses an encoded string?)
inject node > template node (as plain text) > html node, selector: td
Template node content:
<td>some content</td>
<td>blabla<br/><a href="#" rel="nofollow"
title="some title">blabla</a>
</td>
No results.
example flow:
[{"id":"3f0c5e0f41be1217","type":"inject","z":"dd601c6b09710814","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":320,"y":920,"wires":[["4719a15d81f40618"]]},{"id":"4719a15d81f40618","type":"template","z":"dd601c6b09710814","name":"","field":"payload","fieldType":"msg","format":"html","syntax":"plain","template":"<td>some content</td>\n<td>blabla<br/><a href=\"#\" rel=\"nofollow\"\n title=\"some title\">blabla</a>\n</td>\n","output":"str","x":480,"y":920,"wires":[["3b51dad0260b58d7"]]},{"id":"3b51dad0260b58d7","type":"html","z":"dd601c6b09710814","name":"","property":"payload","outproperty":"payload","tag":"td","ret":"text","as":"single","chr":"_","x":610,"y":920,"wires":[["e5af80508a63d73d"]]},{"id":"e5af80508a63d73d","type":"debug","z":"dd601c6b09710814","name":"debug 44","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":740,"y":920,"wires":[]}]
