Hi Guys,
I've discovered a behavior difference of HTML parsing node according to Node-Red version (and maybe node.js version ??).
The following flow is just a "foo" string in msg.palyoad that shall be parsed in msg.payload output a array.
This works well on Node-red v1.2.6 (node.js v12.18.0), but not on v2.1.3 (Node.js v17.1.0).
I've already seen that before, but did put attention on this since a implemented bypass. THis means this issue not only related to that newest version...
I'm sure I'm not the only one facing this issue, but I cannot find any info about it on the web.
Can somebody help to fix this?
[{"id":"f15e247e303f869c","type":"inject","z":"8499110d.f4114","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":330,"y":1400,"wires":[["9fbc3115654d8932"]]},{"id":"9fbc3115654d8932","type":"function","z":"8499110d.f4114","name":"","func":"msg.payload = \"<td>foo</td>\";\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":570,"y":1420,"wires":[["3daf3e4160f3b523"]]},{"id":"3daf3e4160f3b523","type":"html","z":"8499110d.f4114","name":"Get row data","property":"payload","outproperty":"payload","tag":"td","ret":"html","as":"single","x":770,"y":1420,"wires":[["38a638931bab31ce"]]},{"id":"38a638931bab31ce","type":"debug","z":"8499110d.f4114","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":950,"y":1420,"wires":[]}]
