Hi guys,
The http request node seems to be timing out if at least the following properties are added to the message :
- item
- items
As soon as I remove them the call goes through, as soon as they are back in the message object the call fails with TIMEOUT error.
Are these properties used internally in this node ? If so why isn't it documented ?
If not, why isn't the node using only the properties it needs (method, url, headers, requestTimeout, payload), as stated in the documentation.
Thanks in advance for your help
Kind regards
Mathieu
