Hi, I have the same problem as this github (https://github.com/Hypnos3/node-red-contrib-cast/issues/73
) and it says that to solve I have to modify the javascript file inside the module, only when I go to the node_modules folder I do not find the add-on and therefore not even the javascript file
Since you didn't let us know what device/OS you are using, I will provide an answer that would apply if ou were tunning on a raspberry pi using Buster.
ssh into the device and enter cd $HOME.node-red/node_modules/node-red-contrib-cast
and that will put in the folder with the nodes code,
yes you are right sorry, i am using a raspberry pi 3 B +, i installed through SD memory card home assistant (Link).
i ran the command on the shell through putty link but it tells me this error:
You're right, the JavaScript is elsewhere. It is inside of the container (a virtual machine) & typically not accessible because you are using node red from within home assistant.
If Node red were installed outside of home assistant. Then you could access the files.
If you really want to try, you could log into the container and it will be within that directory listed in the GitHub issue.
Alternatively, don't use the home assistant node-red Add-in - instead - install node red locally.
I am afraid I have no idea how a Home Assistant machine is set up.
To find the file on my Raspberry Pi i would run sudo find / -name cast-to-client.js.
But maybe HA has stuff hidden in containers like with Docker.
