in the data I want to create a dashboard using the if else method or whatever,
The first one I want to make is if the DL11_LINE_SPEED data is "0" the dashboard display will change to CO1/CO2/C3/etc status until MC,but when the DL11_LINE_SPEED data > 0 it will display speed numbers. what are the steps? I've tried using var failed.
this for example dashboard, what I want to add here is if the machine is not running/speed "0" then the dashboard will display the status either CO/CO2/CO3/etc until MC like the data in sql server
