[{"id":"5ad8f653.eb1298","type":"tab","label":"Flow 3","disabled":false,"info":""},{"id":"9eafd082.f8802","type":"s7 in","z":"5ad8f653.eb1298","endpoint":"24609e1b.f132d2","mode":"all","variable":"MoistureatReel","diff":true,"name":"PLC Data","x":240,"y":84,"wires":[["bebafa0.2deaf08"]]},{"id":"bebafa0.2deaf08","type":"debug","z":"5ad8f653.eb1298","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":307,"y":175,"wires":},{"id":"4fbe13b6.a48dfc","type":"inject","z":"5ad8f653.eb1298","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":168,"y":288,"wires":[["cbdc8747.162cc8"]]},{"id":"a67295c4.a7a508","type":"http request","z":"5ad8f653.eb1298","name":"","method":"use","ret":"txt","paytoqs":false,"url":"","tls":"","proxy":"","authType":"","x":574,"y":288,"wires":[["cedf224e.58c2c"]]},{"id":"cedf224e.58c2c","type":"debug","z":"5ad8f653.eb1298","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":742,"y":288,"wires":},{"id":"cbdc8747.162cc8","type":"function","z":"5ad8f653.eb1298","name":"Send Data to API ","func":"msg.method = "GET";\nmsg.url = "https://xyz.net/app/storeData?param1=" +msg.payload.MoistureatReel+ "¶m2=param2value¶m3=param3value¶m4=param4value¶m5=param5value¶m6=param6value¶m7=param7value¶m8=param8value¶m9=param9value¶m10=param10value";\nreturn msg; ","outputs":1,"noerr":0,"initialize":"","finalize":"","x":378,"y":288,"wires":[["a67295c4.a7a508"]]},{"id":"24609e1b.f132d2","type":"s7 endpoint","transport":"iso-on-tcp","address":"192.168.200.50","port":"102","rack":"0","slot":"1","localtsaphi":"01","localtsaplo":"00","remotetsaphi":"01","remotetsaplo":"00","connmode":"rack-slot","adapterauto":true,"adapterport":"","busaddr":"2","adapteraddr":"0","cycletime":"500","timeout":"1500","verbose":"default","name":"","vartable":[{"addr":"MR4","name":"MoistureatReel"},{"addr":"MR8","name":"Machine Speed"},{"addr":"MR12","name":"Storage Tower Level"},{"addr":"MR16","name":"Broke Tower Level"},{"addr":"MR20","name":"Turbine Inlet Pressure"},{"addr":"MR24","name":"Turbine Inlet Temperature"},{"addr":"MR28","name":"Bleed Flow"},{"addr":"MR32","name":"Extraction Flow"},{"addr":"MR68","name":"Paper at Size Press"},{"addr":"MR72","name":"Paper at Shoe Press"},{"addr":"MR76","name":"Paper at Dryer 1"},{"addr":"MR80","name":"Paper at Dryer 2"},{"addr":"MR84","name":"Paper at Dryer 3"}]}]
