If in an If doesn't work
Hi everyone,
I want to check if a number is negative or positive.
But untill now, global.set(port + ".NMEA.nav.position.alt.altitude_relative" is not written
if (string[0] == "GGA")
    global.set(port + ".NMEA.UTC.time", string[1]);
    global.set(port + ".NMEA.nav.position.dms.lat", string[2]);
    global.set(port + ".NMEA.nav.position.dms.NS", string[3]);
    global.set(port + ".NMEA.nav.position.dms.lon", string[4]);
    global.set(port + ".NMEA.nav.position.dms.EW", string[5]);
    global.set(port + ".NMEA.nav.fix.fix", string[6]);
    global.set(port + ".NMEA.sat.sat_used", (string[7]*1));
    global.set(port + ".NMEA.nav.position.accuracy.HDOP", string[8] * 1);
    global.set(port + ".NMEA.nav.position.alt.altitude", (string[9]*1));
    global.set(port + ".NMEA.nav.position.alt.altitude_unit", string[10]);
    global.set(port + ".NMEA.nav.position.alt.altitude_ellipsoid", (string[11]*1));
        if (Math.sign(string[11] === -1))
        global.set(port + ".NMEA.nav.position.alt.altitude_relative", ((string[11] - string[9])*-1));
            else if (Math.sign(string[11] === 1))
            global.set(port + ".NMEA.nav.position.alt.altitude_relative", ((string[11] - string[9]) * 1));
    global.set(port + ".NMEA.nav.DGPS.update", string[12]);
    global.set(port + ".NMEA.nav.DGPS.age", (string[13]*1));
    global.set(port + ".NMEA.nav.DGPS.id", string[14]);
What am I doing wrong?
I'm not sure but....
I'm not sure what altitude_ellipsoid mean as you have an altitude already.
So reading it how I see it:
if look at the Math.sign of string[11] and see if it is -1
(IF TRUE)
So let's look at this:
[11] is say..... -5
[9] is 20
-5 - 20 * -1
= -25 * -1
= 25
Isn't the extra * -1 at the end negating things?
Why are you having the last bit (on two lines - though different) of *-1 and * 1?
To me they aren't needed.
But I have been wrong before and will be again.
But to me that is wrong. Somehow.
Hi Trying_to_learn,
the difference between the *-1 and * 1 is that it removes the negative.
If string[11] is negative, do calc and make it positve.
if string[11] is positive, do calc and let it positive.
But I am not sure why this calculation doesn't work at all.
The result is that global.set(port + ".NMEA.nav.position.alt.altitude_relative" is not written to global.
In case of string[11] is 0, there will be no action.
Try to trace down actual values.
That's a good catch @hotNipi
I didn't even think of that one.
My bad, I misunderstood what Math.sign did. :man_facepalming:
Blockquote
The Math.sign() static method returns 1 or -1, indicating the sign of the number passed as argument. If the input is 0 or -0, it will be returned as-is.
That syntax is also wrong I think. It should be:
if (Math.sign(string[11]) === -1)
