I'm not seeing the elephant - code help
Given the message structure is correct:
I am not understanding why I am not seeing the correct output.
//  msg.existing is the EXISTING value for the LEDs
//  Split the payload.
const check = msg.payload.split(",");
node.warn("Wipe " + msg.wipe);
let msg1 = {};
let led = check[1];
if (led != 0)
    node.warn("LED " + led);
    //node.warn(msg.existing);
    let value = msg.existing[led];
    node.warn("Value " + value);
    let x = led + ',' + value;
    node.warn("x is " + x);
    msg1 = {"payload":"rgb," + led + ',' + value};
    node.warn("msg1 " + msg1);
if (msg.wipe == "OLD")
    return [msg.msg1];
else
return [msg,null];
I have a fear I am going to kick myself.
But I'm not too proud to admit I am not seeing the cause.
FOUND IT!
return [msg.msg1]
and not
return [msg,msg1]
SORRY!
Isn't it the other way around?
return [msg,msg1]
and not
return [msg.msg1]
Well, I was saying it in the context of what I had and what I should have put.
So I said I had (originally) return [msg.msg1] rather than return msg, msg1]
AND! I found it all by myself - which is kind of good.
