Hi Folks,
I try to import a backup of my flows from an old Node-Red instance on the new one.
The JSON file size is around 200kb.
My problem is:
Neither the UI nor the API-call to /flows [POST] seems to be able to import it without a timeout (API) or just no error message (UI).
Remark: On the UI I can import the flows to the actual UI, but when I click on any variants of the "deploy" button, it runs for a while and return with no message. No flows are saved when I reload the page.
Is there a way to get this done?
Thx
Can you not just copy the flows file manually, and rename as needed to match new machine name ?
Sorry, but I never have done this before.
So, I assume I have to copy the flows.json file to the remote machine.
But where to place it and what do you mean with:
I should mention, that Node-Red is running as a plugin inside of IoBroker. But I assume that the folder structure is the same.
I'm not familiar with iobroker so not sure what paths it may use.
Typical NR install is something like - /home/"username"/.node-red.
The default file name is flows_"hostname".json
Thanks,
this I will try tomorrow.
As was said, you should directly update flows manually.
At least in my iobroker flows can be found under:
C:\ioBroker\node_modules\iobroker.node-red\userdata
Ok,
go tit done.
What I did:
- stop the Node-Red plugin
- place the "flows.json" file to "/opt/iobroker/iobroker-data/node-red" (and replace the existing one)
- Start Node-Red plugin
- Open the UI -> Nothing is visible. Still only the default empty flow.
- Import the same flow via UI again and deploy it
Now,it only takes a few seconds and it's imported...
Small remark: I use the IoBroker version 6.3.5.
Thx for the small brainstorming
