Import / Export flows or nodes to multiple NODE-RED devices
Hello, I am relatively new to NODE-RED.
I have modified a node in my flow and I would like to export that change to many more devices that have the same program.
There are a lot of IOT devices... about 30...
To export a node to the other devices... the typical thing would be to import that node or flow in each device and click on deploy.
But that is quite cumbersome with so many devices.
My question is if it is possible to do that process of exporting and importing in an automated way in several devices?
Would it be possible or there is nothing...maybe some script or something?
I am working specifically with Siemens IOT 2050/2040 devices. They have NODE-RED.
Thank you very much for your time
You should be able to this using the admin-api methods.
