I have deployed the node-red snap in ubuntu 16 core. Now i want to change the settings.js file how can I change.
As per the project readme
I looked in the /var/snap/node-red/current directory and it's empty. Please advise. I need to get to the settings.js file to enable ssl and other things. Thank you!
UPDATE: I found the settings.js file at /root/snap/node-red/current
I had the same issue and finally found it - it's in /root/snap/node-red/current
UPDATE#2 - I did a snap refresh to upgrade Node-RED to 2.1.4 and now the settings file is no longer under the path above. It is now located at /var/snap/node-red/current
