Finding settings.js
Hi all
I am having a big problem finding the settings.js file in my NR install. I am running it on Rasbian Stretch, and I have tried to update it with the script in the documentation:
bash <(curl -sL https://raw.githubusercontent.com/node-red/raspbian-deb-package/master/resources/update-nodejs-and-nodered)
Unfortunately, the directory still only yields:
lib node_modules package.json package-lock.json
How can I find the settings.js file (or create it) so I can edit it?
(I have done a directory search, many reboots, and many reinstalls)
Thanks!
should be in your .node-red (notice the dot) directory within the home account of the user you are running Node-RED as.
The path is also listed in the startup messages when you restart node-RED.
If you run, in a terminal
node-red-stop
node-red-start
then the startup messages will show you where settings.js is. Since you installed using the pi script then, as @ukmoose said, it should be in the .node-red folder in the home folder of the user that you were logged in as when you ran the script.
Unfortunately it is not there.
It is only copied there after you run Node-RED the first time.
Thanks everyone!
So, there was no settings file for the first few times that I ran the stop and start, as @Colin suggested, but I rebooted the Pi a few times and redid the stop/start a number of times, and it eventually appeared. Not sure why that was the case, but thank you for your help!
When you ran it those first few times what did the start log say about the settingsfile?
If it said that it was in .node-red as expected then perhaps it was a caching issue with whatever you were using to determine whether the file was there or not.
I don't recall seeing any indication of a settings file at all, but that program ran smoothly. This was the main source of confusion; the whole NodeRed install seemed to be running without any settings at all.
I used exactly the same commands to open the directory now to see if the file was in there - I can't really think how I could have done it differently this time. Perhaps I started with:
node-red-start
node-red-stop
@SolarPilz
Have a look here: RED-settings
It returns some infos about node-red:
"nodeRedVersion": "0.19.5",
"dsmVersion": "0.13.4",
"coreNodesDir": "/usr/lib/node_modules/node-red/nodes",
"userDir": "/home/pi/.node-red",
"settingsFile": "/home/pi/.node-red/settings.js",
"logging": "info",
