Editing Settings.js Files Problem , I'm still finding the Settings.js file empty?
After the trouble of searching, I found the settings.js file in /home/pi/.node-red but when I run it by Nano Editor it appears empty without any line and I don't know what the problem is, in previous versions, I could edit it ! what the solution is?
In a terminal run
node-red-stop
node-red-start
and copy/paste what you see here. That may give us some clues.
I see nothing, I used < nano ~ / .node-red / settings.js > cuz I need to edit the file but I don't see the lines inside it.
I meant run those commands and copy/paste what appears in the terminal.
OK Just a minute please
Starting as a systemd service.
14 Apr 16:50:35 - [info]
Welcome to Node-RED
14 Apr 16:50:35 - [info] Node-RED version: v0.20.5
14 Apr 16:50:35 - [info] Node.js version: v8.15.1
14 Apr 16:50:35 - [info] Linux 4.14.71-v7+ arm LE
14 Apr 16:50:36 - [info] Loading palette nodes
14 Apr 16:50:48 - [info] Dashboard version 2.14.0 started at /ui
14 Apr 16:50:49 - [warn] ------------------------------------------------------
14 Apr 16:50:49 - [warn] [node-red-contrib-mqtt-dynamictopic/mqtt-dynamic] Type already registered
14 Apr 16:50:49 - [info] Settings file : /home/pi/.node-red/settings.js
14 Apr 16:50:49 - [info] Context store : 'default' [module=memory]
14 Apr 16:50:49 - [info] User directory : /home/pi/.node-red
14 Apr 16:50:49 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
14 Apr 16:50:49 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
14 Apr 16:50:49 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
so cd into your .node-red directory
list all the files using ls command to check the settings.js file exists and has a size (i.e it’s not a blank file)
and then when you know you are in the right directory and it has a size
try running the nano command again
nano settings.js
pi@raspberrypi:~ cd ~/.node-red pi@raspberrypi:~/.node-red dir
flows_raspberrypi_cred.json package.json settings.js.save.1
flows_raspberrypi.json package-lock.json settings.js.save.2
lib settings.js
node_modules settings.js.save
Try. ls -l. Instead of dir
and building on @dceejay reply if you use the man command you can see what other options a command has
total 252
-rw-r--r-- 1 pi pi 72 Apr 14 16:07 flows_raspberrypi_cred.json
-rw-r--r-- 1 pi pi 14015 Apr 14 17:12 flows_raspberrypi.json
drwxr-xr-x 3 pi pi 4096 Apr 12 16:54 lib
drwxr-xr-x 500 pi pi 20480 Apr 12 22:31 node_modules
-rw-r--r-- 1 pi pi 847 Apr 12 22:31 package.json
-rw-r--r-- 1 pi pi 194628 Apr 12 22:31 package-lock.json
-rw-r--r-- 1 pi pi 0 Apr 12 16:54 settings.js
-rw-r--r-- 1 pi pi 1 Apr 12 22:07 settings.js.save
-rw-r--r-- 1 pi pi 17 Apr 12 22:12 settings.js.save.1
-rw-r--r-- 1 pi pi 1 Apr 14 13:58 settings.js.save.2
So that shows that the settings.js file now has no content and the time it was last changed. The .save files must be from when you have been trying to edit it.
As it has zero content, you could try deleting it (and the .save files) and then restarting Node-RED
Also note that the node node-red-contrib-mqtt-dynamictopic is conflicting with another node. You should uninstall one of them. This is nothing to do with the empty settings file however. I wonder how that happened.
OK ! I will do it, thank you
