Settings file nonexistant after install
Hi, I am new to Node-RED, sorry if this has been answered elsewhere, I couldn't find the answer.
So, I just installed Node-Red, following the instructions from the Getting Started page (https://nodered.org/docs/getting-started/windows) and it will not start. I get this error:
Error loading settings file: \Users\FrancoisStArnaud\.node-red\settings.js
I checked, and the file is not there. I am also unable to launch the extension in VS Code, don't know if there is a link between the two issues.
I have node v12.18.2 and npm 6.14.5
Any help would be greatly appreciated.
Are you sure that is correct? Can you copy from the CMD terminal.
Normally it'll be c:\users\username\.node-red\settings.js
Hi @Steve-Mcl,
There is actually a "" before .node-red, I corrected the original message.
There is a file named settings.js in my folder C:\Users\FrancoisSt-Arnaud\node_modules\node-red, can I copy it directly in \Users\FrancoisStArnaud\.node-red\ and run the "node-red" command?
I don't think you have installed correctly. Looks like you missed the -g part (I could be wrong). I would try again.
Run an CMD terminal as administrator then run npm install -g --unsafe-perm node-red
Ps, delete that node_modules folder from your user folder.
Seems like you were right. I deleted the .node-red and node_modules folders, then re-installed in CMD as admin (I had previously installed in PowerShell). It worked! The settings.js file has been created, I can launch node-red and even connect in the web brower!
Thank you so much!!!
