Include other Widgets into a UI template
Hi folks,
I would like to create a ui_template that contains regular HTML table but also an ui_gauge node.
The reason for this is that the template is to be duplicated multiple times to my dashboard and all of them should be exactly like but with different values. All with a html and a gauge
I don't believe that is possible due to the way that ui nodes are constructed and how Dashboard works. You will need to use custom gauge code.
Can I somehow call the ui gauge from my html?
Quite possibly but I don't use Dashboard much so I don't really know.
