Inquiry Regarding @opcua/for-node-red Usage, Licensing & Alternatives
Dear Sterfive Team,
We are currently evaluating the use of the @opcua/for-node-red package in our industrial automation solution, where Node-RED will be used to communicate with PLCs for reading and writing OPC UA-based attributes.
Could you kindly clarify the following:
  1. Licensing Requirements:
  • Does the use of @opcua/for-node-red in a production environment require a commercial license?
  • If yes, please provide the cost and duration details for a typical deployment.
  • Is there a free/open-source tier for non-commercial or limited use?
  1. Node Capabilities:
  • Does this node fully support both reading and writing to PLC attributes?
  • Are there any limitations or restrictions in its current version?
  1. Alternative Nodes:
  • Are there other free and open-source OPC UA Node-RED nodes that you would recommend for basic read/write operations with PLCs?
We aim to finalize our technology stack soon and would appreciate your input to make an informed decision.
Looking forward to your response.
Best regards,
Vinay M
Technical Architect
Wipro Technologies
[Contact Info] +91-9502981672
Hi @Vinnu - welcome to the forum.
You may have more luck asking on the developers public repository here: GitHub · Where software is built
ok let me check
You can see the license here.
@Steve-Mcl is it normal that we include on the node-red flows page, nodes that cannot be used without paying a royalty? This is the first time I have noticed such a node there.
Im getting above license error where can I buy license and what would be the duration of license the @opcua/for-node-red from sterfive.com
A contrib node must be in the library to be available in the palette manager, so yes, this is valid.
@Vinnu the node does (should) (used to) offer a single server unlicenced - so you can try out the features before you buy. As soon as you add a 2nd server to the node, the license is required.
If you delete all server configs except 1 then restart node-red, the single free license becomes operational again.
Is there any free version of opcua node for interacting with PLC IoT devices? if so please give the nodes to be used that can be used even in production version
Several: Library - Node-RED
But the more popular OPCUA node is: node-red-contrib-opcua (node) - Node-RED
let me check on this node node-red-contrib-opcua (node) - Node-RED
other than node-red-contrib-opcua (node) - Node-RED do we have any other free version for this .
