HI
I have this data coming from a MQTT connect to my weather station:
dataGMTTime=2023/07/05 03:38:46
cwinfo=Serial: 2387, FW: 5.88
clouds=34.350000
temp=34.310000
wind=-1
gust=-1
rain=2450
lightmpsas=23.57
switch=0
safe=0
hum=45
dewp=20.680000
rawir=46.190000
abspress=1014.687500
relpress=1015.816851
I create a Windows MYSQL database table:
SELECT `timestamps`.`create_time`,
`timestamps`.`clouds`,
`timestamps`.`temp`,
`timestamps`.`wind`,
`timestamps`.`gust`,
`timestamps`.`rain`,
`timestamps`.`lightmpsas`,
`timestamps`.`dew`,
`timestamps`.`rawir`,
`timestamps`.`abspress`,
`timestamps`.`relpress`
FROM `obs`.`timestamps`;
SELECT * FROM obs.timestamps;
Here are the nodes, HTTP get from the weather station, the function that I get from Lunatico connected to a Switch node to the gauge etc.
"id": "274d0c55f0ce31c2",
"type": "inject",
"z": "347a75cd5d16739c",
"name": "5 secs",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "30",
"topic": "",
"payload": "",
"payloadType": "str",
"x": 130,
"y": 120,
"3c89cda003e1ada5"
"id": "3c89cda003e1ada5",
"type": "http request",
"name": "Solo last data",
"method": "GET",
"ret": "txt",
"paytoqs": "ignore",
"url": "http://1xxxxxxxxx/cgi-bin/cgiLastData",
"tls": "",
"persist": false,
"proxy": "",
"insecureHTTPParser": false,
"authType": "basic",
"senderr": false,
"headers": [],
"x": 200,
"y": 180,
"a618203e92f9ec15",
"14ae07e98da30ed0"
"id": "14ae07e98da30ed0",
"type": "function",
"name": "process-data",
"func": "\nlet payload = msg.payload;\n\nlet data_out = {}\n\nif (payload == \" \")\n\n return;\n\n//node.log(\"payload=\" +typeof payload +\" \"+payload);\n\nlet data = payload.split(\"\\n\");\n\nnode.log(\"data =\" + data);\n\nif (typeof data == \"undefined\" || data == \"\")\n\n node.log(\"empty\");\n\nfor (let i = 0; i < data.length; i++) {\n\n\n\n let line = data[i].split(\"=\");\n\n msg.topic = line[0];\n\n if (line[0] == \"clouds\" || line[0] == \"dewp\" || line[0] == \"rawir\")\n\n line[1] = parseFloat(line[1]).toFixed(2);\n\n if (line[0] == \"abspress\" || line[0] == \"relpress\" || line[0] == \"lightmpsas\")\n\n line[1] = parseFloat(line[1]).toFixed(2);\n\n if (line[0] == \"temp\") {\n\n line[1] = parseFloat(line[1]) * 9 / 5 + 32;\n\n line[1] = line[1].toFixed(2);\n\n }\n\n msg.payload = line[1]\n\n data_out[line[0]] = line[1]; //make object\n\n if (typeof msg.topic != \"undefined\" || msg.topic != \"\") {\n\n node.send(msg);\n\n node.log(\"sent \" + msg.topic);\n\n }\n\n\n\n}\n\nnode.log(\"out_data = \" + JSON.stringify(data_out));\n\nlet temp_time = data_out[\"dataGMTTime\"];\n\nlet d = new Date(temp_time);\n\nlet timestamp = d.getTime();\n\nnode.log(\"timestamp=\" + timestamp);\n\nlet clouds = data_out[\"clouds\"];\n\nlet temp = data_out[\"temp\"];\n\nlet wind = data_out[\"wind\"];\n\nlet gust = data_out[\"gust\"];\n\nlet rain = data_out[\"rain\"];\n\nlet lightmpsas = data_out[\"lightmpsas\"];\n\nlet hum = data_out[\"hum\"];\n\nlet dewp = data_out[\"dewp\"];\n\nlet rawir = data_out[\"rawir\"];\n\nlet abspress = data_out[\"abspress\"];\n\nlet relpress = data_out[\"relpress\"];\n\nmsg.params = { $timestamp: timestamp, $clouds: clouds, $temp: temp, $wind: wind, $gust: gust, $rain: rain, $lightmpsas: lightmpsas, $hum: hum, $dewp: dewp, $rawir: rawir, $abspress: abspress, $relpress: relpress };\n\nmsg.topic = \"database\";\n\nnode.send(msg);",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 430,
"y": 180,
"d6c48eb9cf006939"
"id": "a618203e92f9ec15",
"type": "mqtt out",
"name": "MQTT",
"topic": " something",
"qos": "",
"retain": "",
"respTopic": "",
"contentType": "",
"userProps": "",
"correl": "",
"expiry": "",
"broker": "b231b989b9dfe837",
"x": 365,
"y": 120,
"wires": [],
"l": false
"id": "d9e5318a8e660990",
"type": "mqtt in",
"topic": "something",
"qos": "2",
"datatype": "auto-detect",
"broker": "c1d150f1e0ea035e",
"nl": false,
"rap": true,
"rh": 0,
"inputs": 0,
"x": 190,
"y": 240,
"id": "b231b989b9dfe837",
"type": "mqtt-broker",
"broker": "mosquitto.org",
"port": "xxxx",
"clientid": "",
"autoConnect": true,
"usetls": false,
"protocolVersion": "4",
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
"id": "c1d150f1e0ea035e",
"port": "xxxx",
"clientid": "",
"usetls": false,
"keepalive": "60",
"autoUnsubscribe": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"birthMsg": {},
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"closeMsg": {},
"willTopic": "",
"willQos": "0",
"willPayload": "",
"willMsg": {},
"userProps": "",
"sessionExpiry": ""
I am struggling to find the way to insert this data, any help to guide me me will be appreciate
[ Moderator edit to format code, use pencil icon yo see the edit ]
