HI,
We have an existing solution running on WebSphere ND. We want to have applications generated by Node Red running on this Application Server. How would we go about this?
- Install Node-Red on WebSphere
- Install Node-Red locally and build the application, then export it somehow and deploy the application to WebSphere.
Any pointers ?
Many thanks
Benjamin
              Node-RED runs on a node.js runtime... not sure how that works on Websphere ND if at all. Happy to be corrected  if it can. You could of course stand up a node.js machine/instance next to it and use then call the various APIs from Node-RED. (or maybe call out to Node-RED from it)
              Hi
Thanks. Then I need to develop some sort of forward from the WebSphere to the Node.js server
/Benjamin
              I know nothing about Websphere ND, but a quick search finds this piece of documentation about deploying node.js apps - https://www.ibm.com/support/knowledgecenter/en/SSAW57_liberty/com.ibm.websphere.wlp.nd.multiplatform.doc/ae/twlp_deployservice_nodejs.html
That would be your starting point.
Nick
I saw this, but it refers to WebSphere Liberty Profile which isn't the same as ND. I will dig a little deeper but from previous experience Liberty and ND are two quite different beasts, especially when it comes to configuration / deployment
/Benjamin
