Install Oracle client on existing nodered container
As I spent few days to sort out oracle connection with exsting nodered container,
I'd like to share how I solved the problem as following.
  1. download oracle client zip file: ( in my case target oracle version is 11g )
    Unauthorized Request
    Instant Client for Linux x86-64 (64-bit)
  2. Copy inside docker container
docker cp zipFile norered:/data
  1. Access docker as root
    sudo docker exec -it --user root nodered /bin/bash
  2. After creating /data/oracle, copy the zip file and unzip it.
    /data/oracle/instantclient_11_2 is created
  3. Create soft link
    ln -s libclntsh.so.11.1 libclntsh.so
    ln -s libocci.so.11.1 libocci.so
  4. Install lib ( libaio, libnsl )
    apk update
    apk add libaio
    apk add libnsl
  5. Set docker environment variable LD_LIBRARY_PATH from host
    sudo su
    systemctl stop docker
    • The following path is different based on your container
      vi /var/lib/docker/containers/ed76126653847ec5658983e2dd2da94fe96268b087887d52a6ec12e473ea301a/config.v2.json
    Add the following to Env
    "Env":["LD_LIBRARY_PATH=/data/oracle/instantclient_11_2:/usr/lib",
    systemctl start docker
    docker start nodered
  6. Execute oracle DB query using oracle node
I never use docker.
Your tutorial can be applied for this NodeRed and Oracle Database ?
