Installed npm install node-red-contrib-onvif-nodes@0.0.1-beta.16 Node Onvif does not exist
Hi, I'm new to the field and have a question about installing from:
onvif-camera-control
on Raspberry Pi 4
After installation, I can't find the Onvif node in Node Red?
I've already tried restarting Node Red and also Raspberry.
Anyone have any tips?
Welcome to the forum @staebchen0
Refresh the web page in the browser.
If that doesn't help, were you in the correct folder when you ran the npm install command? For a normal node-red install you should be in the .node-red folder. If you believe you were in that folder then, from that folder, what does this show
npm list node-red-contrib-onvif
Also stop node-red and start it again in a terminal and copy/paste the full terminal output here please.
Hi, I have the installation in the directory
pi@raspianja:~/node_modules $ sudo npm install node-red-contrib-onvif-nodes@0.0.1-beta.16
changed 1 package, and audited 68 packages in 5s
2 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
executed again. And restarted Node Red and refreshed the browser. But the ONVIF nodes are not displayed to me.
I have additional
Installed. This is also displayed to me as a node.
But through the installation
no more onvif nodes have been added
onvif
I just found something interesting.
The directory
was created and also contains the corresponding files
sorry for the circumstances! I found it.
I didn't see the .node-red folder.
after I installed everything in this folder, the nodes are also displayed :slight_smile:
