Installing dependency modules when cloning project to server
Hi there!
Currently I am cloning my project to two other linux PCs, which are set up identical to the the source system.
When starting node-red first time on the clone I setup the git and switch to the branch needed.
Then I restart node-red.
then I get the message that there are many nodes missing and it offers me to manage the missing dependencies. However the list is empty.
On the forum I found that the project package.json is not used by node-red at startup, so it needs to be copied to the local user first. If I copy the package.json from the project to the local user (only the dependencies section) and restart node-red I get the same. Meaning:
  • project dependencies windows is empty
  • palette manager is empty
Nowehere I can see the list of missing modules in order to install them.
What is the intended procedure to install modules upon fresh clone of a project?
Thanks a lot!
FYI: my dependencies list looks like this:
  "dependencies": {
        "@abandonware/noble": "^1.9.2-14",
        "node-beacon-scanner-duplicates-check": "^0.2.0",
        "node-red-contrib-beacon-scanner": "~1.0.1",
        "node-red-contrib-tts-ultimate": "~1.0.40",
        "node-red-contrib-ui-media": "~1.2.0",
        "node-red-dashboard": "~2.30.0",
        "node-red-node-mysql": "~1.0.1",
        "node-red-node-tail": "~0.3.2",
        "node-red-node-ui-table": "~0.3.12"
Copy the whole package.json across, go into the .node-red folder and run npm install in that folder, then start node red.
Thanks for the pointer, Colin!
Unfortunately this started to install things and then procuded a lot of errors.
I started node-red anyway to see if any module got installed and noticed that suddenly I got a proper list of missing dependencies. So I thought let's install them as proposed by the node-red GUI.
I started with ui-table and it was not possible to get it installed. The error log is as follows:
2024-03-16T19:08:04.963Z Installieren : node-red-node-ui-table ~0.3.12
2024-03-16T19:08:04.164Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-node-ui-table@~0.3.12
2024-03-16T19:08:05.339Z [err] npm
2024-03-16T19:08:05.340Z [err]  WARN config production Use `--omit=dev` instead.
2024-03-16T19:08:23.070Z [err] npm
2024-03-16T19:08:23.071Z [err]  WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T19:08:23.073Z [err] npm
2024-03-16T19:08:23.074Z [err] WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T19:08:23.076Z [err] npm
2024-03-16T19:08:23.076Z [err] WARN
2024-03-16T19:08:23.077Z [err] deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T19:08:23.111Z [err] npm
2024-03-16T19:08:23.112Z [err]
2024-03-16T19:08:23.113Z [err] WARN
2024-03-16T19:08:23.113Z [err] deprecated
2024-03-16T19:08:23.114Z [err]  querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
2024-03-16T19:08:23.158Z [err] npm WARN
2024-03-16T19:08:23.159Z [err]  deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
2024-03-16T19:08:23.439Z [err] npm
2024-03-16T19:08:23.439Z [err] WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
2024-03-16T19:08:58.744Z [err] npm
2024-03-16T19:08:58.745Z [err]
2024-03-16T19:08:58.745Z [err] ERR!
2024-03-16T19:08:58.746Z [err] code
2024-03-16T19:08:58.746Z [err]  1
2024-03-16T19:08:58.747Z [err] npm
2024-03-16T19:08:58.748Z [err] ERR!
2024-03-16T19:08:58.749Z [err] path
2024-03-16T19:08:58.749Z [err]  /home/nodered/.node-red/node_modules/microsoft-cognitiveservices-speech-sdk
2024-03-16T19:08:58.754Z [err] npm
2024-03-16T19:08:58.755Z [err]
2024-03-16T19:08:58.755Z [err] ERR!
2024-03-16T19:08:58.755Z [err]  command failed
2024-03-16T19:08:58.756Z [err] npm
2024-03-16T19:08:58.756Z [err] ERR!
2024-03-16T19:08:58.757Z [err]
2024-03-16T19:08:58.757Z [err] command
2024-03-16T19:08:58.757Z [err]  sh -c npm install --package-lock-only --ignore-scripts --no-audit && npx npm-force-resolutions
2024-03-16T19:08:58.758Z [err] npm
2024-03-16T19:08:58.758Z [err] ERR!
2024-03-16T19:08:58.758Z [err]  npm ERR! code EBADENGINE
2024-03-16T19:08:58.759Z [err] npm
2024-03-16T19:08:58.759Z [err] ERR!
2024-03-16T19:08:58.759Z [err]  npm ERR! engine Unsupported engine
2024-03-16T19:08:58.760Z [err] npm
2024-03-16T19:08:58.760Z [err] ERR!
2024-03-16T19:08:58.760Z [err]  npm ERR! engine Not compatible with your version of node/npm: eslint-plugin-jsdoc@39.9.1
2024-03-16T19:08:58.761Z [err] npm
2024-03-16T19:08:58.761Z [err] ERR!
2024-03-16T19:08:58.761Z [err]  npm ERR! notsup Not compatible with your version of node/npm: eslint-plugin-jsdoc@39.9.1
2024-03-16T19:08:58.762Z [err] npm
2024-03-16T19:08:58.762Z [err] ERR!
2024-03-16T19:08:58.762Z [err]  npm ERR! notsup Required: {"node":"^14 || ^16 || ^17 || ^18 || ^19"}
2024-03-16T19:08:58.763Z [err]
2024-03-16T19:08:58.763Z [err] ERR!
2024-03-16T19:08:58.763Z [err]  npm ERR! notsup Actual:   {"npm":"10.2.4","node":"v20.11.1"}
2024-03-16T19:08:58.767Z [err]  ERR!
2024-03-16T19:08:58.767Z [err] npm ERR! npm ERR! A complete log of this run can be found in: /home/nodered/.npm/_logs/2024-03-16T19_08_28_495Z-debug-0.log
2024-03-16T19:08:58.772Z [err]
2024-03-16T19:08:58.773Z [err] npm
2024-03-16T19:08:58.773Z [err]  ERR! A complete log of this run can be found in: /home/nodered/.npm/_logs/2024-03-16T19_08_05_185Z-debug-0.log
2024-03-16T19:08:58.850Z rc=1
From the last lines do I guess correct, that I may have a too high version of node.js (v20)?
Yes, you should submit an error against the nodes that say that. Then install 18 and run
npm rebuild
And
npm install
Ok, thanks!
Did as you proposed and tried installing again the ui-table. Now I am getting errors related to a module that is also on the list (abandonwarenoble), but different from what I am trying to install now (ui-table).
I removed the module from the user node-red directory and tried again. Failure.
The log I get is:
2024-03-16T20:00:46.118Z Installieren : node-red-node-ui-table 0.x
2024-03-16T20:00:45.335Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-node-ui-table@0.x
2024-03-16T20:00:46.765Z [err] npm
2024-03-16T20:00:46.766Z [err]  WARN
2024-03-16T20:00:46.767Z [err]  config production Use `--omit=dev` instead.
2024-03-16T20:01:33.118Z [err] npm
2024-03-16T20:01:33.119Z [err]  WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
2024-03-16T20:01:33.178Z [err] npm
2024-03-16T20:01:33.179Z [err] WARN deprecated formidable@1.2.2: Please upgrade to latest, formidable@v2 or formidable@v3! Check these notes: https://bit.ly/2ZEqIau
2024-03-16T20:01:33.560Z [err] npm WARN
2024-03-16T20:01:33.560Z [err]  deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T20:01:33.748Z [err] npm
2024-03-16T20:01:33.749Z [err] WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
2024-03-16T20:01:33.792Z [err] npm WARN
2024-03-16T20:01:33.792Z [err]  deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T20:01:34.137Z [err] npm WARN
2024-03-16T20:01:34.137Z [err]  deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
2024-03-16T20:03:25.671Z [err] npm
2024-03-16T20:03:25.671Z [err]  ERR! code 1
2024-03-16T20:03:25.672Z [err] npm
2024-03-16T20:03:25.672Z [err] ERR! path /home/nodered/.node-red/node_modules/@abandonware/noble
2024-03-16T20:03:25.678Z [err] npm ERR!
2024-03-16T20:03:25.679Z [err]  command failed
2024-03-16T20:03:25.679Z [err] npm ERR! command sh -c node-gyp-build
2024-03-16T20:03:25.679Z [err]  gyp info it worked if it ends with ok
2024-03-16T20:03:25.679Z [err] npm ERR! gyp info using node-gyp@10.0.1
2024-03-16T20:03:25.680Z [err]  ERR! gyp info using node@18.19.1 | linux | x64
2024-03-16T20:03:25.680Z [err] npm
2024-03-16T20:03:25.680Z [err] ERR! gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"
2024-03-16T20:03:25.680Z [err] npm ERR!
2024-03-16T20:03:25.680Z [err]  gyp info spawn /usr/bin/python3
2024-03-16T20:03:25.681Z [err] ERR! gyp info spawn args [
2024-03-16T20:03:25.681Z [err] npm
2024-03-16T20:03:25.681Z [err] ERR! gyp info spawn args '/home/nodered/.node-red/node_modules/node-gyp/gyp/gyp_main.py',
2024-03-16T20:03:25.681Z [err] npm ERR!
2024-03-16T20:03:25.681Z [err]  gyp info spawn args 'binding.gyp',
2024-03-16T20:03:25.681Z [err]  gyp info spawn args '-f',
2024-03-16T20:03:25.681Z [err]  gyp info spawn args 'make',
2024-03-16T20:03:25.681Z [err]  gyp info spawn args '-I',
2024-03-16T20:03:25.682Z [err]  gyp info spawn args '/home/nodered/.node-red/node_modules/@abandonware/noble/build/config.gypi',
2024-03-16T20:03:25.682Z [err] npm ERR! gyp info spawn args '-I',
2024-03-16T20:03:25.682Z [err] npm ERR! gyp info spawn args '/home/nodered/.node-red/node_modules/node-gyp/addon.gypi',
2024-03-16T20:03:25.682Z [err]  ERR! gyp info spawn args '-I',
2024-03-16T20:03:25.682Z [err]  ERR! gyp info spawn args '/home/nodered/.cache/node-gyp/18.19.1/include/node/common.gypi',
2024-03-16T20:03:25.682Z [err]  ERR! gyp info spawn args '-Dlibrary=shared_library',
2024-03-16T20:03:25.682Z [err] ERR! gyp info spawn args '-Dvisibility=default',
2024-03-16T20:03:25.682Z [err] ERR! gyp info spawn args '-Dnode_root_dir=/home/nodered/.cache/node-gyp/18.19.1',
2024-03-16T20:03:25.683Z [err] ERR! gyp info spawn args '-Dnode_gyp_dir=/home/nodered/.node-red/node_modules/node-gyp',
2024-03-16T20:03:25.683Z [err] npm ERR!
2024-03-16T20:03:25.683Z [err]  gyp info spawn args '-Dnode_lib_file=/home/nodered/.cache/node-gyp/18.19.1/<(target_arch)/node.lib',
2024-03-16T20:03:25.683Z [err]  gyp info spawn args '-Dmodule_root_dir=/home/nodered/.node-red/node_modules/@abandonware/noble',
2024-03-16T20:03:25.683Z [err]  gyp info spawn args '-Dnode_engine=v8',
2024-03-16T20:03:25.683Z [err]  gyp info spawn args '--depth=.',
2024-03-16T20:03:25.683Z [err] npm ERR! gyp info spawn args '--no-parallel',
2024-03-16T20:03:25.683Z [err] npm ERR! gyp info spawn args '--generator-output',
2024-03-16T20:03:25.684Z [err] npm ERR! gyp info spawn args 'build',
2024-03-16T20:03:25.684Z [err] npm ERR! gyp info spawn args '-Goutput_dir=.'
2024-03-16T20:03:25.684Z [err] npm ERR! gyp info spawn args ]
2024-03-16T20:03:25.684Z [err] npm ERR! gyp ERR! build error
2024-03-16T20:03:25.684Z [err] npm ERR! gyp ERR! stack Error: not found: make
2024-03-16T20:03:25.684Z [err] npm ERR! gyp ERR! stack at getNotFoundError (/home/nodered/.node-red/node_modules/which/lib/index.js:16:17)
2024-03-16T20:03:25.685Z [err]  ERR! gyp ERR! stack at which (/home/nodered/.node-red/node_modules/which/lib/index.js:77:9)
2024-03-16T20:03:25.685Z [err] npm
2024-03-16T20:03:25.685Z [err]  ERR! gyp ERR! stack at async doWhich (/home/nodered/.node-red/node_modules/node-gyp/lib/build.js:112:22)
2024-03-16T20:03:25.685Z [err] ERR! gyp ERR! stack at async loadConfigGypi (/home/nodered/.node-red/node_modules/node-gyp/lib/build.js:77:7)
2024-03-16T20:03:25.685Z [err] ERR! gyp ERR! stack at async build (/home/nodered/.node-red/node_modules/node-gyp/lib/build.js:35:3)
2024-03-16T20:03:25.685Z [err] ERR! gyp ERR! stack at async run (/home/nodered/.node-red/node_modules/node-gyp/bin/node-gyp.js:81:18)
2024-03-16T20:03:25.685Z [err] npm ERR!
2024-03-16T20:03:25.685Z [err]  gyp ERR! System Linux 6.1.0-18-amd64
2024-03-16T20:03:25.685Z [err]  gyp ERR! command "/usr/bin/node" "/home/nodered/.node-red/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2024-03-16T20:03:25.686Z [err]  gyp ERR! cwd /home/nodered/.node-red/node_modules/@abandonware/noble
2024-03-16T20:03:25.686Z [err] npm ERR! gyp ERR! node -v v18.19.1
2024-03-16T20:03:25.686Z [err] npm ERR! gyp ERR! node-gyp -v v10.0.1
2024-03-16T20:03:25.686Z [err]  ERR! gyp ERR! not ok
2024-03-16T20:03:25.693Z [err]
2024-03-16T20:03:25.693Z [err] npm ERR! A complete log of this run can be found in: /home/nodered/.npm/_logs/2024-03-16T20_00_46_577Z-debug-0.log
2024-03-16T20:03:25.792Z rc=1
I am a bit out of ideas, short of reinstaling the whole system again and installing every module by hand. That process worked on the first clone I made a week ago. However to me it seems not the right way to go for clean cloning of the server. :frowning:
Other ideas?
What do you mean? What exactly did you do and why?
Well, due to the messages relating to that module I removed it from the node-red user directory. It seemed to cause trouble and was not fully installed.
npm rebuild said it was successful after that.
  1. try to install ui-table => got errors related to another module (abandonwarenoble)
  2. delete abandonwarenoble from node-red user dir
  3. npm rebuild
  4. install ui-table again => still errors relating to abandonwarenoble
Are you 100% certain this is your actual node-red user directory? Usually it is /home/.node-red/
This is a good clue that your system doesn't have all the necessary tools. I.e if on Ubuntu, you should do sudo apt-get install build-essential first (or the equivalent on non Debian system)
Did you install node red using the recommended Debian/Ubuntu/pi script? I thought it checked that build-essential is installed.
yes, this is the user directory of the nodered user. Why would it be ´/home/.node-red´? Under which user is node-red running in such a case?
Yes, I used the recommended Debian script - and yes, I also thought it would install build essentials. On the original (running) system it did and it was never a problem to install nodes from source. Also on dev machines that was always fine. So I really wonder what changed this time.
I will completely set up the system new. As I am not certain what has been different. Maybe I did miss a step in my procedure.
Thanks for the helpful pointers! I will keep you posted onthe result of the new install.
Cheers
Just install build-essential
Note - the script does not check or install build-essential ... as per the docs
(as it is not 100% needed in all circumstances) - so it is recommended but up to the user to install if necessary.
OK, then we have the reason for the failures or manual install.
So what is left, is the question: What is the intended procedure to transfer projects to another machine and take care of all dependencies?
Same as before, however install the required tools first (the command in the yellow tip section)
As a quick follow up. The command npm build worked well right after installing build essentials.
I will try to recreate the procedure on a virgin server one of these days to see if package dependencies get shown properly in node-red.
Cheers
