Installing "node-red-contrib-discord-advanced" causing crash of my node-red
Hello all
i just install the node-red-contrib-discord-advanced today and my node red is not available anymore. I am unable to restart it.
this is the starting message i have received from the command line
Welcome to Node-RED
8 Dec 17:20:49 - [info] Node-RED version: v3.1.0
8 Dec 17:20:49 - [info] Node.js version: v18.17.1
8 Dec 17:20:49 - [info] Linux 6.1.21-v8+ arm64 LE
8 Dec 17:20:50 - [info] Loading palette nodes
8 Dec 17:20:59 - [info] Dashboard version 3.6.1 started at /ui
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (ca_FR.UTF-8)
8 Dec 17:21:01 - [info] Settings file : /home/openhabian/.node-red/settings.js
8 Dec 17:21:01 - [info] Context store : 'default' [module=memory]
8 Dec 17:21:01 - [info] User directory : /home/openhabian/.node-red
8 Dec 17:21:01 - [warn] Projects disabled : editorTheme.projects.enabled=false
8 Dec 17:21:01 - [info] Flows file : /home/openhabian/.node-red/flows.json
8 Dec 17:21:02 - [info] Server now running at http://127.0.0.1:1880/
8 Dec 17:21:02 - [warn] Using unencrypted credentials
8 Dec 17:21:02 - [info] Starting flows
8 Dec 17:21:02 - [info] [hue-bridge:Bridge sous-sol] Initializing the bridge (192.168.1.160)…
8 Dec 17:21:02 - [info] KNX-Unsecure: connection to insecure interface/router using node KNX Gateway
8 Dec 17:21:05 - [info] Started flows
8 Dec 17:21:05 - [info] [hue-bridge:Bridge sous-sol] Connected to bridge
8 Dec 17:21:05 - [red] Uncaught Exception:
8 Dec 17:21:05 - [error] Error [TokenInvalid]: An invalid token was provided.
at WebSocketManager.connect (/home/openhabian/.node-red/node_modules/discord.js/src/client/websocket/WebSocketManager.js:136:26)
at Client.login (/home/openhabian/.node-red/node_modules/discord.js/src/client/Client.js:228:21)
at /home/openhabian/.node-red/node_modules/node-red-contrib-discord-advanced/discord/lib/discordBotManager.js:28:11
at new Promise ()
at Object.getBot (/home/openhabian/.node-red/node_modules/node-red-contrib-discord-advanced/discord/lib/discordBotManager.js:6:17
at new discordMember (/home/openhabian/.node-red/node_modules/node-red-contrib-discord-advanced/discord/discordMember.js:10:23)
at Object.createNode (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/util.js:157:27)
at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/Flow.js:260:54)
at async Object.start [as startFlows] (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/flows/index.js:398:17)
Someone can guide for a walk around?
If i reinstall node red. Will i lost all the previous node?
Note: i think that the token i provide has cause the problem
Thank's in advance
Just start node-red in safe mode (search forum for safe mode), fix your error then deploy
