during last Openhabian update I decided to update Node-Red also.
The Node-Red itself seems to be updated to v0.20.0 but it stopped working, as a result I get “Lost connection to server…” message from UI.
I’ve noticed that the installer couldn’t update Node.js and left old one.
Does anyone knows how to fix it?
Below update status:
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js -
Leave existing Node.js - Node v8.15.1 Npm 6.9.0
Clean npm cache -
Install Node-RED core ✔ 0.20.0
Move global nodes to local ✔
Install extra Pi nodes -
Npm rebuild existing nodes -
Add shortcut commands ✔
Update systemd script ✔
Also node-red-log after node-red-start:
12 Mar 22:34:47 - [info] Started flows
12 Mar 22:34:47 - [info] [mqtt-broker:ecc62bcb.53b478] Connected to broker: mqtt://localhost:1883
12 Mar 22:34:47 - [info] [mqtt-broker:349b5a3d.e108c6] Connected to broker: mqtt://localhost:1883
12 Mar 22:34:52 - [red] Uncaught Exception:
12 Mar 22:34:52 - TypeError: Converting circular structure to JSON
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Unit entered failed state.
nodered.service: Failed with result 'exit-code'.
nodered.service: Service hold-off time over, scheduling restart.
Stopped Node-RED graphical event wiring tool.
12 Mar 22:34:55 - [info]
Welcome to Node-RED
12 Mar 22:34:55 - [info] Node-RED version: v0.20.0
12 Mar 22:34:55 - [info] Node.js version: v8.15.1
12 Mar 22:34:55 - [info] Linux 4.14.98-v7+ arm LE
12 Mar 22:34:56 - [info] Loading palette nodes
Regards,
Pawel
