I don't see the error message in the log you provided.
If it appears in the debug pane it is probably coming from one of the nodes in your flow (meaning node red has disconnected from a server of some sort that you have configured). Show us a screenshot of the message. If the message has a node name or id above it then search for that name or id using Ctrl+F to find which node it is.
Nodejs 15 is not yet recommended for node-red (and probably never will be, the next recommended version will be 16 I think). That could be the problem if a node you are using is not compatible with nodejs 15.
I don't know about the Firebase node, but if you show us how you have configured it and what, if anything, you are sending to it then someone may be able to help, however you might be better to start a new thread with Firebase in the title so that someone who knows about it might see it.
