I am trying to set a child value in firebase but every time i try to deploy, i receive the message "Lost connection to server", "i am using node-red-contrib-firebase" nothing is show to me different on cmd.
I did everything just like this tutorial https://www.youtube.com/watch?v=IItfEkeh9cA&t=14s.
Start node red in a terminal, if you are on a pi and used the recommended pi install script then that do this by
node-red-stop
node-red
and post the resulting log here.
It is already flagged as general man.
I am on windows.
Well start it in a terminal whatever is the windows way of doing that and post the log here.
node-red-stop
Doesn't work on windows.
As I said in my last post, start node red and post the log.
Welcome to Node-RED
18 Jan 11:02:19 - [info] Node-RED version: v1.0.3
18 Jan 11:02:19 - [info] Node.js  version: v12.13.1
18 Jan 11:02:19 - [info] Windows_NT 10.0.18362 x64 LE
18 Jan 11:02:21 - [info] Loading palette nodes
18 Jan 11:02:24 - [info] Dashboard version 2.19.3 started at /ui
18 Jan 11:02:24 - [info] Settings file  : C:\Users\nribe.node-red\settings.js
18 Jan 11:02:24 - [info] Context store  : 'default' [module=memory]
18 Jan 11:02:24 - [info] User directory : C:\Users\nribe.node-red
18 Jan 11:02:24 - [warn] Projects disabled : editorTheme.projects.enabled=false
18 Jan 11:02:24 - [info] Flows file     : C:\Users\nribe.node-red\flows_Nathan.json
18 Jan 11:02:24 - [info] Creating new flow file
your credentials.
18 Jan 11:02:24 - [info] Server now running at /
18 Jan 11:02:24 - [info] Starting flows
18 Jan 11:02:24 - [info] Started flows
18 Jan 11:02:52 - [info] Installing module: node-red-contrib-firebase, version: 1.1.1
18 Jan 11:02:59 - [info] Installed module: node-red-contrib-firebase
18 Jan 11:02:59 - [info] Added node types:
18 Jan 11:02:59 - [info]  - node-red-contrib-firebase:firebase config
18 Jan 11:02:59 - [info]  - node-red-contrib-firebase:firebase modify
18 Jan 11:02:59 - [info]  - node-red-contrib-firebase:firebase.once
18 Jan 11:02:59 - [info]  - node-red-contrib-firebase:firebase ondisconnect
18 Jan 11:02:59 - [info]  - node-red-contrib-firebase:firebase auth
18 Jan 11:04:58 - [info] Stopping flows
18 Jan 11:04:58 - [info] Stopped flows
after deployed
18 Jan 11:04:58 - [info] Starting flows
18 Jan 11:04:58 - [info] Started flows
nothing happens and continue to show "Lost connection to server"
Makes no sense this doesn't work what i think is that this pallet doesn't work anymore with Firebase.
Have a look at the node's github page. It says "unfortunately, this repo is no longer maintained and is known to not work with the latest versions of node-red / Firebase."
I will try mqtt
