Welcome to the forum @ThaiMinh120
You will need to provide a lot more information
- What hardware/OS are you running node-red on?
- What version of node-red and of nodejs (use node -v to find that)
- What node have you installed to provide the firebase connection (possibly node-red-contrib-something)?
- Export those two nodes and paste them here. See this post for more details - How to share code or flow json
node red V2.2.2
I tried "add firebase" and "firebase modify on" but still disconnected.
I use node-red of IOT 2050 SIEMENS to connect with FIREBASE
"id": "e8f171d0c52224be",
"type": "tab",
"label": "Flow 1",
"disabled": false,
"info": "",
"env": []
"id": "5f10828627f79098",
"type": "inject",
"z": "e8f171d0c52224be",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 180,
"y": 260,
"1f61c4a56460d81a"
"id": "1f61c4a56460d81a",
"type": "firebase modify",
"firebaseconfig": "",
"childpath": "temp",
"method": "set",
"value": "msg.payload",
"priority": "msg.priority",
"x": 540,
"y": 260,
"8f7d03985b37e0a6"
"id": "97e8d40883a4301c",
"type": "addFirebase",
"firebaseCertificate": "e30baa99c8afb322",
"client_email": "",
"private_key": "",
"data": "",
"propertyType": "str",
"method": "get",
"newchildpath": "",
"x": 370,
"y": 380,
"6f3cbd357779e9e9"
"id": "5725efacef1eebf4",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 180,
"y": 380,
"97e8d40883a4301c"
"id": "8f7d03985b37e0a6",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 850,
"y": 260,
"id": "6f3cbd357779e9e9",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 550,
"y": 380,
"id": "e30baa99c8afb322",
"type": "firebaseCertificate",
"firebaseurl": "iot2050-87b5a-default-rtdb",
"loginType": "none"
Hi, I suggest you to use an updated Firebase palette because many palettes no longer work or don't support different URLs.
I recommend the following:
You will find the documentation on the Wiki.
PS: I am the maintainer ![]()
I can't download node red of you
It would be helpful to know more. What do you mean? Do you have an error in the logs? ...
