Newbie alert!
Installing the above ocpp but get the following warnings regarding peer dependencies.
Can someone please tell me what to do? I presume I need to install something else - but what exactly?
Warnings don't normally cause a node not to work
You are not installing into the node-red directory.
Easier method:
Use the editor, hamburger menu -> manage palette -> install tab -> search the node -> install.
Normally that should be enough. Is it not working?
So far it does seem to be!
Fingers crossed - thanks!
