Would you mind teaching me on How to Integrate Sigfox with Node-red ?
Hi we help but we don't Teach
1 read sigfox API docs
https://support.sigfox.com/docs/api-documentation
2 Have look at stevesnoderedguide.com
Node-Red HTTP Request Node for Beginners
Thank you for your support.
I want to be guided to Connect Sigfox to node-red.
Would you mind helping me?
Ummm @iiLaw did just help you, have you followed his guidance?
I cannot find any information about the Integration.
The first thing you should do is search the forum using 'sigfox' as a keyword and read all the results to see what you can learn and how others have used it.
Maybe someone from one of those threads will offer some help.
But you have not provided any specifications on where node-red is, how you want to connect, what data you need to pass back and forth, what you are trying to accomplish, what versions of the software(s) you are using.
That will mean someone wanting to help you will spend a lot of their time trying to get that information.
The best way to get help is to make it as easy as possible for someone to help you using the least amount of their time. (like not having to spend their time explaining all this to you.)
Oh yeah, what have you tried so far??
I'm trying to connect Thinger.io with node-red then Blynk.
as in this site:
[https://programarfacil.com/blog/arduino-blog/estacion-meteorologica-solar-arduino-sigfox/?utm_content=bufferb0cdc&utm_medium=social&utm_source=twitter.com&utm_campaign=buffer&fbclid=IwAR3cPZuNKxSqDANEecxVnTmodwSh8-Hfph4j82s2ab7ucWFDD_eKf-gvcGA]
So is issue about connecting node-red with thinger.io ?
yes, but in general I need to connect my sigfox to blynk.
So, If there is anyway to connect sigfox to bylnk using node-red, I wish to use it.
My graduation project relies on this thing.
