Hi everyone,
I'm currently engaged in integrating the Worldmap node inside the Node-RED Dashboard 2.0. However, the dashboard does not provide a direct way to include the Worldmap node. I would prefer not to use an iframe due to security concerns.
I attempted to load the
worldmap.jsfile as a script within the UI template node, but the map still doesn't display in the dashboard UI. Any insights or suggestions on how to resolve this issue would be highly appreciated. -
Attached the code and defected output image for reference
<template> <!-- Div container for the map --> <div id="worldmap" style="height: 400px;"></div> </template> <script type="text/javascript"> // Ensure the script runs after the DOM has fully loaded document.addEventListener('DOMContentLoaded', function() { var script = document.createElement('script'); script.src = "/worldmap.js"; // Adjust path if necessary script.onload = function() { // Assuming worldMap.createMap is a valid function var map = worldMap.createMap('worldmap', { center: [51.505, -0.09], zoom: 13 }); L.marker([51.5, -0.09]).addTo(map) .bindPopup('A marker on the map.') .openPopup(); }; document.head.appendChild(script); }); </script> -
Thank you!
