Worldmap for Dashboard 2
So I want to use the Worldmap on my dashboard, which I've already made using the dashboard V2.
Is that possible by any chance?
I'm aware I can use it on a separate webpage, but is it possible on the same dashboard?
I did find the documentation for it, saying I'll have to use a template node. Is there a workaround? I'm not proficient in js.
Thanks in advance!
There is an example here in the docs: UI Template Examples | Node-RED Dashboard 2.0
No need for any javascript, just copy + paste that into a Template node and you'll be up and running.
I do have plans to improve the worldmap integration in the near future as its a very common request
