Interpret MQTT object and update output according to which parameter is available
From one source (shelly1pmplus) I am receiving different objects on the same MQTT address:
E.g.
For the measured current:
{"src":"shellyplus1pm-441793cfda38","dst":"shellyplus1pm-pvbalkon/events","method":"NotifyStatus","params":{"ts":1663331015.85,"switch:0":{"id":0,"current":0.7}}}
or
For the measured power:
{"src":"shellyplus1pm-441793cfda38","dst":"shellyplus1pm-pvbalkon/events","method":"NotifyStatus","params":{"ts":1663331015.85,"switch:0":{"id":0,"apower":153.4}}}
How is it possible to parse for the specific values and forward to e.g. an influx database seperately?
The only difference between the two messages seems to be that one has msg.payload.params["switch:0"].apower while the other has msg.payload.params["switch:0"].current.
You could use a switch node to test for the existence of msg.payload.params["switch:0"].apower:
Untitled 1
Are they sometimes both there?
As far as I observed there is always only one. But there are more than these two messages. How do I handle three or more?
maybe try msg.payload.params["switch:0"] and test has key string apower etc
The final solution
        "id": "e8302ea3fbb3a7d9",
        "type": "mqtt in",
        "z": "f6f2187d.f17ca8",
        "name": "PV Balkon",
        "topic": "shellyplus1pm-pvbalkon/events/rpc",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "b912bc20557e4732",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 100,
        "y": 3580,
                "489a4e6e68885a07"
        "id": "489a4e6e68885a07",
        "type": "switch",
        "property": "payload.params[\"switch:0\"].apower",
        "propertyType": "msg",
        "rules": [
                "t": "nnull"
                "t": "null"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 250,
        "y": 3680,
                "ceef30dcabb6bd3a"
                "92ea03355df26eaa"
        "id": "92ea03355df26eaa",
        "type": "switch",
        "property": "payload.params[\"switch:0\"].current",
        "rules": [
                "t": "nnull"
                "t": "null"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 330,
        "y": 3760,
                "b7506c5431cae1ec"
                "927abb61de571cf2"
        "id": "927abb61de571cf2",
        "type": "switch",
        "property": "payload.params[\"switch:0\"].aenergy",
        "rules": [
                "t": "nnull"
                "t": "null"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 450,
        "y": 3840,
                "9e40c5ba36c4beee"
                "03a1613c2e8ecf46"
        "id": "03a1613c2e8ecf46",
        "type": "debug",
        "name": "nothing",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 480,
        "y": 3940,
        "id": "ceef30dcabb6bd3a",
        "type": "function",
        "name": "apower",
        "func": "msg.payload = msg.payload.params[\"switch:0\"].apower;\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 340,
        "y": 3600,
                "627178e3b76fa724"
        "id": "b7506c5431cae1ec",
        "type": "function",
        "name": "current",
        "func": "msg.payload = msg.payload.params[\"switch:0\"].current;\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 460,
        "y": 3680,
                "89780d26bfac53e4"
        "id": "9e40c5ba36c4beee",
        "type": "function",
        "name": "aenergy",
        "func": "msg.payload = msg.payload.params[\"switch:0\"].aenergy;\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 600,
        "y": 3780,
                "930e3b5e8b93fa4c",
                "bb313777d8e9c8c2",
                "6e998650359928ba",
                "12a7282a88077905",
                "a4038beb7c256672"
        "id": "930e3b5e8b93fa4c",
        "type": "function",
        "name": "aenergy_total",
        "func": "msg.payload = msg.payload.total;\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 880,
        "y": 3780,
                "7f5da6a85a103648",
                "45e625f26e3c6f1e"
        "id": "bb313777d8e9c8c2",
        "type": "function",
        "name": "aenergy_minute_ts",
        "func": "msg.payload = msg.payload.minute_ts;\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 890,
        "y": 3840,
                "10ef6a290f00c758"
        "id": "6e998650359928ba",
        "type": "function",
        "name": "aenergy_by_minute_0",
        "func": "msg.payload = msg.payload.by_minute[0];\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 3900,
                "85e8c13f43995435"
        "id": "12a7282a88077905",
        "type": "function",
        "name": "aenergy_by_minute_1",
        "func": "msg.payload = msg.payload.by_minute[1];\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 3960,
                "a4dba4e489edff63"
        "id": "a4038beb7c256672",
        "type": "function",
        "name": "aenergy_by_minute_2",
        "func": "msg.payload = msg.payload.by_minute[2];\nreturn msg",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 900,
        "y": 4020,
                "df892f8e02ea102e"
        "id": "7f5da6a85a103648",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1100,
        "y": 3780,
        "id": "10ef6a290f00c758",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1110,
        "y": 3840,
        "id": "85e8c13f43995435",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1120,
        "y": 3900,
        "id": "a4dba4e489edff63",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1120,
        "y": 3960,
        "id": "df892f8e02ea102e",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1140,
        "y": 4020,
        "id": "627178e3b76fa724",
        "type": "influxdb out",
        "influxdb": "af175a885afb64ae",
        "name": "pv_balkon_apower",
        "measurement": "pv_balkon_apower",
        "precision": "",
        "retentionPolicy": "",
        "database": "database",
        "precisionV18FluxV20": "ms",
        "retentionPolicyV18Flux": "",
        "org": "organisation",
        "bucket": "bucket",
        "x": 530,
        "y": 3600,
        "id": "89780d26bfac53e4",
        "name": "pv_balkon_current",
        "measurement": "pv_balkon_current",
        "precision": "",
        "bucket": "bucket",
        "x": 650,
        "y": 3680,
        "id": "45e625f26e3c6f1e",
        "name": "pv_balkon_aenergy_total",
        "measurement": "pv_balkon_aenergy_total",
        "precision": "",
        "bucket": "bucket",
        "x": 1130,
        "y": 3720,
        "id": "b912bc20557e4732",
        "type": "mqtt-broker",
        "name": "Rapserry Pi Daten 1",
        "broker": "192.168.0.76",
        "port": "1883",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "af175a885afb64ae",
        "type": "influxdb",
        "hostname": "192.168.0.76",
        "port": "8086",
        "protocol": "http",
        "database": "shellyDB",
        "name": "Shellys",
        "usetls": false,
        "tls": "",
        "influxdbVersion": "1.x",
        "url": "http://localhost:8086",
        "rejectUnauthorized": true
I am not able to look at your flow at the moment, but if you can choose the measurement name based on the property name, perhaps you don't need to test it at all. Perhaps you can use the property name directly in the influx write.
