I have historical data stored in a SQL Database as Datum in the format (2017.10.27 12:00:25) and the corresponding Temp in the format (26.55). I am using the node iot_datasourse to show the data and the debug message shows the time and the corresponding temperature, but the dashboard doesn't show any graphic. The flow nodes are as follows, I would appreciate some help
[{"id":"280b51a9.1d20ee","type":"iot-datasource","z":"a287c70.b313638","name":"Temperature_historical_data","tstampField":"tstamp","dataField":"data","disableDiscover":false,"x":800,"y":420,"wires":[["d2f6ac7.9847f5"]]},{"id":"174ee565.e02b2b","type":"function","z":"a287c70.b313638","name":"Temp","func":"var p =msg.payload;\n\nfor(var i=0;i<p.length;i++){\n var dUnix =Date.parse(p[i].Datum);\n node.send({payload:{data:p[i].Temp, tstamp:dUnix}});\n}\nreturn;","outputs":1,"noerr":0,"x":590,"y":420,"wires":[["280b51a9.1d20ee","5f0d558f.04310c"]]},{"id":"a74a3ded.a929e","type":"MSSQL","z":"a287c70.b313638","mssqlCN":"e1823c68.173aa","name":"database_sql","query":"","outField":"payload","x":430,"y":420,"wires":[["174ee565.e02b2b"]]},{"id":"542c5d2d.ed21e4","type":"inject","z":"a287c70.b313638","name":"","topic":"","payload":"SELECT * FROM [test].[Temp]","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":420,"wires":[["a74a3ded.a929e"]]},{"id":"5f0d558f.04310c","type":"debug","z":"a287c70.b313638","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":770,"y":340,"wires":[]},{"id":"d2f6ac7.9847f5","type":"debug","z":"a287c70.b313638","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1010,"y":340,"wires":[]},{"id":"e1823c68.173aa","type":"MSSQL-CN","z":"","name":"SQL","server":"localhost","encyption":true,"database":"test"}]
