I would like to bundle only the necessarry code from node-red. I tried to use webpack for this purpose, but it`s always throws errors. I was wondering if it is possible, at all.
Any tips to reduce size/ number of files are greatly appreciated.
Could you explain your specific use case for this, e.g., are you attempting to embed your node-red install into a different application? There might be solutions based on the kind of use case you’re working with.
Yes it is embedded in to a nodejs application.
Webpack is surely for front-end packaging not back-end?
Webpack does
- transformations (e.g. Javascript Contructs not supported on target platform),
- bundling (creating one file with the relevant code parts)
- treeshaking (remove all code parts which are not relevant for the use case)
- compressing
My use case is embedding node-red for AWS Lambda. Bundeling and tree shaking helps a lot to reduce the cold start timings.
We have used Node-RED inside AWS Lambda successfully. It can work pretty well.
Cheers,
Paul
@paulkeates I know - I have it working too, but the bundle size is 10MB+
OK - I got it now bundled an compressed with parcel down to on javascript file with 1.3MB. This file needs no node_modules folder and runs on any system with node 14.x
I will update this thread with my configuration when I have finished my tests next week.
Awesome compression results! I'd be interested to see how you accomplished that...
Cheers,
Paul
I am happy to share a first ALPHA version of my Node-RED bundler:
Current Results:
- Packagesize (Simple Event IN->OUT flow): 1.5MB
- Lambda Coldstart Duration: 50ms / Init Duration: 350.54 ms
- Lambda recurrent calls Duration: 1.8-2.0ms (Memory Size: 1024 MB Max Memory Used: 89 MB)
I am happy to hear your Feedback.
