Is it possible to encrypt the Node-Red dashboard?
Usually, in the case of Node-Red encryption, encryption of the flow is usually possible.
Similarly, is there a way to access the dashboard only by entering account access information, just like encryption is applied to the flow when accessing the Node-Red UI screen?
Are you trying to restrict unauthenticated access from your local network to node-red and the dashboard?
Check out the documentation: Securing Node-RED : Node-RED
If you are planning to expose node-red to the internet, I created a small little service that might help you get what you want: Noralink - secure access to node-red via the internet
There are many ways to go about it. It just depends on the value of what you are trying to protect and how much effort you want to put into it. If you are looking for a full-blown solution to manage it for you, check us out at FlowFuse.
