Is it possible to let node-red edit discreted parts of the application?
I have a express app for providing backend restful API.
index.js :slight_smile:
const express = require('express')
const app = express()
// add
app.get('/hello', (req, res) => {
  // logic steps
  let a = 'hello,'
  let b = 'world!'
  let c = a + b
  res.send(c)
app.get('/foo', (req, res) => {
  // logic steps
  let data = handlerFoo(req)
  res.send(c)
app.get('/bar', (req, res) => {
  // logic steps
  let data = handlerBar(req)
  res.send(data)
function handlerFoo(req) {
function handlerBar(req) {
app.listen(3000, () => {
  console.log(`Example app listening on port 3000}`)
is it possible to use node-red to edit the handler function? I mean use node-red to write the logic steps for all handlers, the handlerFoo , handlerBar implements by node-RED.
If you are asking whether Node-RED can host a restful API similar to what you have written in your code, then the answer is yes.
This example in the cookbook shows how to setup an HTTP endpoint in Node-RED: Create an HTTP Endpoint : Node-RED
I updated my post, please check it, I only want the node-red to implement one step (function) in a HTTP request-response flow.
You can embed Node-RED into your app as described here: Embedding into an existing app : Node-RED
That will allow Node-RED to handle any requests that your own routes don't cover - assuming you have the flow defined in Node-RED to handle the route.
