Thanks Colin.
Do you mean by using the button node?
[{"id":"d332c5f44a92d664","type":"ui_button","z":"e0129591b64c21bc","name":"","group":"c9af264e236d9442","order":18,"width":3,"height":1,"passthru":false,"label":"Visualizza Famiglie Esistenti","tooltip":"","color":"","bgcolor":"#A6BBCF","className":"","icon":"","payload":"payload[1]","payloadType":"flow","topic":"Le famiglie esistenti sono:","topicType":"str","x":180,"y":1260,"wires":[["95081c31aea3614e","d7ef55c75ada7677"]]},{"id":"95081c31aea3614e","type":"MSSQL","z":"e0129591b64c21bc","mssqlCN":"6fb70e68d89e36c4","name":"","outField":"payload","returnType":"0","throwErrors":"0","query":"SELECT FAMIGLIA FROM [DB_Strumentazione].[dbo].[StrumentazioneAttrezzature]\nGROUP BY FAMIGLIA","modeOpt":"","modeOptType":"query","queryOpt":"","queryOptType":"editor","paramsOpt":"queryParams","paramsOptType":"msg","rows":"","rowsType":"msg","params":[{"output":true,"name":"CODIFICA","type":"VarChar","options":{"nullable":true,"primary":false,"identity":false,"readOnly":false}}],"x":420,"y":1260,"wires":[["fe5175807e83799e","36f3c336c290ba0a"]]},{"id":"fe5175807e83799e","type":"ui_toast","z":"e0129591b64c21bc","position":"dialog","displayTime":"7","highlight":"red","sendall":true,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"className":"","topic":"","name":"","x":650,"y":1260,"wires":[["46e7ca8675a3e147"]]},{"id":"36f3c336c290ba0a","type":"debug","z":"e0129591b64c21bc","name":"out DB","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":510,"y":1200,"wires":[]},{"id":"d7ef55c75ada7677","type":"debug","z":"e0129591b64c21bc","name":"button","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":270,"y":1200,"wires":[]},{"id":"46e7ca8675a3e147","type":"debug","z":"e0129591b64c21bc","name":"notif","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":730,"y":1320,"wires":[]},{"id":"c9af264e236d9442","type":"ui_group","name":"Group 1","tab":"c4b6a8a406b3fbe5","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"6fb70e68d89e36c4","type":"MSSQL-CN","name":"DB_Strumentazione","server":"GIOVANNAQ\\SQLEXPRESS","port":"","encyption":true,"trustServerCertificate":true,"database":"DB_Strumentazione","useUTC":false,"connectTimeout":"","requestTimeout":"","cancelTimeout":"","pool":"","parseJSON":false,"enableArithAbort":true},{"id":"c4b6a8a406b3fbe5","type":"ui_tab","name":"Inserimento Strumento-Attrezzatura","icon":"dashboard","order":3,"disabled":false,"hidden":true}]
