Push MS SQL query data into dashboard list node
Hi all,
currently I have no idea how to feed a list node on my dashboard.
What I am trying to achieve:
I do have a ms sql database wich gives me simple basic data (two coloumns).
The dashboard should display this data in a list node.
In my opinion following steps are needed:
1. fetch data from db:
I use a template node which holds the query
SELECT typ, designation FROM t_bd_planes
This works quite well and I get the data as payload object
Full message:
[{"typ":"D-5909","designation":"Arcus"},{"typ":"D-4002","designation":"Ventus 2cx"},{"typ":"OE-9513","designation":"DG-1001M"},{"typ":"D-5809","designation":"Duo Discus"},{"typ":"OE-5663","designation":"FOX"},{"typ":"OE-5280","designation":"ASK 21"},{"typ":"OE-5664","designation":"LS8"},{"typ":"D-6521","designation":"LS1"},{"typ":"D-3578","designation":"LS4"},{"typ":"OE-5338","designation":"LS4"},{"typ":"OE-5563","designation":"LS4"},{"typ":"OE-5211","designation":"ASK 13"},{"typ":"D-3987","designation":"ASK 13"},{"typ":"D-8525","designation":"Ka 8"},{"typ":"OE-5287","designation":"Ka 8"},{"typ":"OE-5295","designation":"Ka 8"},{"typ":"OE-0772","designation":"Ka 8"},{"typ":"D-KNAM","designation":"SF-25C Falke"},{"typ":"OE-ARD","designation":"Husky"}]
2. Feed the list node
What my problem no is, how do I convert the payload to an readable list node array.
To split the problem I tried to feed the node manually by injecting data in json format.
Therefore i set the injection mode to json
Json data:
The list then gets displayed on my dashboard
Is it possible to push the data directly from the query part to the list node by converting the payload object to a json object?
THX for guiding hints!
You could return the query results as title and description
e.g.
SELECT typ AS title, designation AS description FROM t_bd_planes
Or you can convert them in node-red using a change node and JSONata
e.g.
[{"id":"aa8dbc4e579d61b8","type":"inject","z":"bf622e623503117a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"typ\":\"D-5909\",\"designation\":\"Arcus\"},{\"typ\":\"D-4002\",\"designation\":\"Ventus 2cx\"},{\"typ\":\"OE-9513\",\"designation\":\"DG-1001M\"},{\"typ\":\"D-5809\",\"designation\":\"Duo Discus\"},{\"typ\":\"OE-5663\",\"designation\":\"FOX\"},{\"typ\":\"OE-5280\",\"designation\":\"ASK 21\"},{\"typ\":\"OE-5664\",\"designation\":\"LS8\"},{\"typ\":\"D-6521\",\"designation\":\"LS1\"},{\"typ\":\"D-3578\",\"designation\":\"LS4\"},{\"typ\":\"OE-5338\",\"designation\":\"LS4\"},{\"typ\":\"OE-5563\",\"designation\":\"LS4\"},{\"typ\":\"OE-5211\",\"designation\":\"ASK 13\"},{\"typ\":\"D-3987\",\"designation\":\"ASK 13\"},{\"typ\":\"D-8525\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-5287\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-5295\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-0772\",\"designation\":\"Ka 8\"},{\"typ\":\"D-KNAM\",\"designation\":\"SF-25C Falke\"},{\"typ\":\"OE-ARD\",\"designation\":\"Husky\"}]","payloadType":"json","x":210,"y":500,"wires":[["a4c9f3544e8dda11"]]},{"id":"a4c9f3544e8dda11","type":"change","z":"bf622e623503117a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.{\"title\": $.typ, \"description\":$.designation, \"icon\": \"icon link\"}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":560,"wires":[["eae82cbf44ee5289","8d3d9027c15d88fc"]]},{"id":"eae82cbf44ee5289","type":"ui_list","z":"bf622e623503117a","group":"2d4fe667.28f8ba","name":"","order":27,"width":0,"height":0,"lineType":"three","actionType":"none","allowHTML":false,"outputs":0,"topic":"","x":370,"y":500,"wires":[]},{"id":"8d3d9027c15d88fc","type":"debug","z":"bf622e623503117a","name":"debug 264","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":490,"y":560,"wires":[]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":2,"disp":true,"width":"12","collapse":false,"className":""},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Expression
$$.payload.{
   "title": $.typ,
   "description":$.designation,
   "icon": "icon link"
And here is both with html <b> and adding icon to db return with title and description.
[{"id":"aa8dbc4e579d61b8","type":"inject","z":"bf622e623503117a","name":"inject db return typ, designation","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"typ\":\"D-5909\",\"designation\":\"Arcus\"},{\"typ\":\"D-4002\",\"designation\":\"Ventus 2cx\"},{\"typ\":\"OE-9513\",\"designation\":\"DG-1001M\"},{\"typ\":\"D-5809\",\"designation\":\"Duo Discus\"},{\"typ\":\"OE-5663\",\"designation\":\"FOX\"},{\"typ\":\"OE-5280\",\"designation\":\"ASK 21\"},{\"typ\":\"OE-5664\",\"designation\":\"LS8\"},{\"typ\":\"D-6521\",\"designation\":\"LS1\"},{\"typ\":\"D-3578\",\"designation\":\"LS4\"},{\"typ\":\"OE-5338\",\"designation\":\"LS4\"},{\"typ\":\"OE-5563\",\"designation\":\"LS4\"},{\"typ\":\"OE-5211\",\"designation\":\"ASK 13\"},{\"typ\":\"D-3987\",\"designation\":\"ASK 13\"},{\"typ\":\"D-8525\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-5287\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-5295\",\"designation\":\"Ka 8\"},{\"typ\":\"OE-0772\",\"designation\":\"Ka 8\"},{\"typ\":\"D-KNAM\",\"designation\":\"SF-25C Falke\"},{\"typ\":\"OE-ARD\",\"designation\":\"Husky\"}]","payloadType":"json","x":270,"y":500,"wires":[["a4c9f3544e8dda11"]]},{"id":"a4c9f3544e8dda11","type":"change","z":"bf622e623503117a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload.{\t   \"title\": \"<b>\" & $.typ & \"</b>\",\t   \"description\":$.designation,\t   \"icon\": \"icon link\"\t}","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":520,"wires":[["eae82cbf44ee5289","8d3d9027c15d88fc"]]},{"id":"eae82cbf44ee5289","type":"ui_list","z":"bf622e623503117a","group":"2d4fe667.28f8ba","name":"","order":27,"width":0,"height":0,"lineType":"three","actionType":"none","allowHTML":true,"outputs":0,"topic":"","x":710,"y":560,"wires":[]},{"id":"8d3d9027c15d88fc","type":"debug","z":"bf622e623503117a","name":"debug 264","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":520,"wires":[]},{"id":"e9a87236dcb6fb1d","type":"change","z":"bf622e623503117a","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$$.payload ~> |$|{\"title\": \"<b>\" & $.title & \"</b>\", \"icon\": \"iconlink\"}|","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":500,"y":580,"wires":[["eae82cbf44ee5289"]]},{"id":"eaa1e35511e7cc40","type":"inject","z":"bf622e623503117a","name":"inject db return title, description","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"title\":\"D-5909\",\"description\":\"Arcus\",\"icon\":\"icon link\"},{\"title\":\"D-4002\",\"description\":\"Ventus 2cx\",\"icon\":\"icon link\"},{\"title\":\"OE-9513\",\"description\":\"DG-1001M\",\"icon\":\"icon link\"},{\"title\":\"D-5809\",\"description\":\"Duo Discus\",\"icon\":\"icon link\"},{\"title\":\"OE-5663\",\"description\":\"FOX\",\"icon\":\"icon link\"},{\"title\":\"OE-5280\",\"description\":\"ASK 21\",\"icon\":\"icon link\"},{\"title\":\"OE-5664\",\"description\":\"LS8\",\"icon\":\"icon link\"},{\"title\":\"D-6521\",\"description\":\"LS1\",\"icon\":\"icon link\"},{\"title\":\"D-3578\",\"description\":\"LS4\",\"icon\":\"icon link\"},{\"title\":\"OE-5338\",\"description\":\"LS4\",\"icon\":\"icon link\"},{\"title\":\"OE-5563\",\"description\":\"LS4\",\"icon\":\"icon link\"},{\"title\":\"OE-5211\",\"description\":\"ASK 13\",\"icon\":\"icon link\"},{\"title\":\"D-3987\",\"description\":\"ASK 13\",\"icon\":\"icon link\"},{\"title\":\"D-8525\",\"description\":\"Ka 8\",\"icon\":\"icon link\"},{\"title\":\"OE-5287\",\"description\":\"Ka 8\",\"icon\":\"icon link\"},{\"title\":\"OE-5295\",\"description\":\"Ka 8\",\"icon\":\"icon link\"},{\"title\":\"OE-0772\",\"description\":\"Ka 8\",\"icon\":\"icon link\"},{\"title\":\"D-KNAM\",\"description\":\"SF-25C Falke\",\"icon\":\"icon link\"},{\"title\":\"OE-ARD\",\"description\":\"Husky\",\"icon\":\"icon link\"}]","payloadType":"json","x":270,"y":580,"wires":[["e9a87236dcb6fb1d"]]},{"id":"2d4fe667.28f8ba","type":"ui_group","name":"demo","tab":"1caa8458.b17814","order":2,"disp":true,"width":"12","collapse":false,"className":""},{"id":"1caa8458.b17814","type":"ui_tab","name":"Demo","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Thank you I edited the query as you suggested and it worked on first try.
THX have a good one!
