Hi I have 53mb of cacache, is it safe in Node-RED to remove these
and what command to use, I am using Linux.
safe - yeah. Recommended - not really, but no harm either.
sudo npm cache clean --force
But 53MB is not really a lot TBH.
Thanks Steve,
I am backing up to Google drive and for the npm it will take hours, because of all the small files ?
Or can I not back these up and if I restore to Node-RED in the future, will it still work correctly ?
No need to backup anything in .npm
Thanks Colin, I won't back it up ![]()
This forum is great for helping people like me out ![]()
In addition, in your .node-red folder where the flows file is (assuming you have a conventional install) then you don't need to backup the node_modules folder which can be huge. If you have to restore then you cd into the .node-red folder and run npm install and it will restore it by installing any extra nodes you need.
