Is the dashboard TEMPLATE node standard with the dashboard?
If the correct dashboard (node-red-dashboard) is the template node installed by default?
The ui-template node is yes
You can see this in manage palette
I am helping someone else and I sent them a flow with the dashboard's template node.
They say the node isn't installed.
I assumed they had the dashboard installed, so I needed to check.
Thanks.
