Is there a range limit for node-red-contrib-i2c 'i2c out' node payload value? Looking at the NR module node code I don't any defined limit for a single byte value to be defined as signed? It should be unsigned 0-255. for example, using a tsl2591 sensor, to fully power up the sensor, you have to send a byte value of 147. However, this generates the following error:
"RangeError: The value of "value" is out of range. It must be >= -128 and <= 127. Received 147"
This appears to be a limitation from the underlying node module 'i2c-bus' right?
