Is there an issue with the reliability of Pi GPIO nodes and the raspberry pi 5?
I'm having an issue with multiple raspberry pi 5's where the GPIO inputs are not recognized reliably after editing/deploying a flow a few times. The inputs are switches tied between the GPIO pins and GND, with the GPIO pin set to "input-pullup".
The node i'm using is the default Pi GPIO V2.0.6.
This is running on a Pi 5 with a fresh install of Debian bookworm 64bit
To note, if i deploy the flow but only deploy the modified nodes, there doesnt seem to be an issue. It only occurs when I deploy the GPIO node multiple times and then the switches go into a "floating" state, where if the switch is flipped multiple times it may work 10% of the time.
Any help greatly appreciated!
I am not able to test this as I don't have the hardware, but we might get some useful information from the log.
Run node-red-reload, which will stop and start node-red and leave it showing the log output. Then attempt to reproduce the issue, then post the full log here please, from startup.
Here's the log from running node-red-reload.
I removed my original flow and only have 3 gpioin nodes.
This time, after deploying once, the nodes are not reliable any more.
I can switch the switches and sometimes they stick high and sometimes they don't respond, rebooting the pi fixes the problem.
raspberry@raspberrypi:~ $ node-red-reload
Stop Node-RED
Use node-red-start to start Node-RED again
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.268:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
2 Feb 08:22:13 - [info]
Welcome to Node-RED
2 Feb 08:22:13 - [info] Node-RED version: v4.0.8
2 Feb 08:22:13 - [info] Node.js version: v20.18.1
2 Feb 08:22:13 - [info] Linux 6.6.62+rpt-rpi-v8 arm64 LE
2 Feb 08:22:13 - [info] Loading palette nodes
2 Feb 08:22:15 - [info] Settings file : /home/raspberry/.node-red/settings.js
2 Feb 08:22:15 - [info] Context store : 'default' [module=memory]
2 Feb 08:22:15 - [info] Context store : 'storeInFile' [module=localfilesystem]
2 Feb 08:22:15 - [info] User directory : /home/raspberry/.node-red
2 Feb 08:22:15 - [warn] Projects disabled : editorTheme.projects.enabled=false
2 Feb 08:22:15 - [info] Flows file : /home/raspberry/.node-red/flows.json
2 Feb 08:22:15 - [warn] Encrypted credentials not found
2 Feb 08:22:15 - [info] Server now running at http://127.0.0.1:1880/
2 Feb 08:22:15 - [info] Starting flows
2 Feb 08:22:15 - [info] [ui-base:My Dashboard] Node-RED Dashboard 2.0 (v1.21.0) started at /dashboard
2 Feb 08:22:15 - [info] [ui-base:My Dashboard] Created socket.io server bound to Node-RED port at path /dashboard/socket.io
2 Feb 08:22:15 - [info] Started flows
2 Feb 08:22:38 - [info] Stopping flows
2 Feb 08:22:38 - [info] Stopped flows
2 Feb 08:22:38 - [info] Updated flows
2 Feb 08:22:38 - [info] Starting flows
2 Feb 08:22:38 - [info] Started flows
There doesn't seem to be anything obviously wrong there.
Certainly the Pi guys have totally re-implemented the GPIO hardware on the Pi5 so I guess there is no doubt also a low level software change to try to make it backwards compatible. I guess we may be falling into some timing issue or other oddness here - but sadly I don't have a Pi5 to play with - (to many Pi2,3,4 already) - so it will need someone to dig into the GPIO node/python code to figure it out.
Yes i'm seeing some other posts about the Pi 5 and GPIO issues. Looking at the pi gpio history, it hasn't been updated in 2 years is that correct? If so there might definitely be issues with compatibility with the Pi 5.
I retested the pi gpio node on a pi4 and theres no issues there after multiple deploys so definitely leaning towards the pi5 compatibility problem.
